Daren Woodall
Charging Troubles
Post by Daren Woodall » Mon Dec 23, 2002 4:48 pm
Recently after making some tuning changes, I disconnected the negative battery poll to flush KAM. I reconnecting the battery poll and started the engine. I noticed the low voltage indicator on my instrument panal remained lit. Also, the voltage guage showed low.
I didn't suspect this problem was tied to the recent disconnection of the battery. I felt the voltage guage had been showing low for some time.
I pulled the alternator and had it bench tested by Autozone. They confirmed the alternator was bad as it produced 12.5 volts under load. For good measure, I had them measure a new (rebuild) alternator which produced 15 volts for comparison. I purchased the new alternator and installed it. I restarted the car and saw no change. Still, no charging.
Could disconnecting and reconnecting the battery poll blown a fuse? What do you think and where should I look?
I appreciate any help here,
94GT, AFR165, E303, 1.72 RR, GT-40 Intake, 70mm TB, 24lb inj, ProM 75, BBK LT, J4J1, PLX M-300 WB
Daren Woodall
Post by Daren Woodall » Tue Dec 24, 2002 5:07 pm
Thanks to the kindness of a fellow car club member, I gained access the the charging system schematics identifying a 20amp fuse in the underhood fuse panel that had blown.
I don't know for certain if the fuse blew as a result of disconnecting and reconnecting the battery but the two events coincided together.
Users browsing this forum: Google [Bot] and 21 guests
