AFR_ERROR
alollich
AFR_ERROR
Post by alollich » Wed Mar 14, 2018 7:49 pm
I am trying to use the mapping tool (MAF vs AFR ERROR) in BE to check my MAF curve. The curve I am using is from PRO-M on an older 24lb meter with FMS 24lb injectors. When I load a recent 60 second or so log into the mapping tool I get the error which reads "The data log must contain MAF, VMAF, AFR_ERROR before a map can be populated". I am logging MAF, VMAF, LAMBSE1, and LAMBSE2. I don't see an afr error to log. Is there something else I am supposed to log or am I just flat doing something wrong. I am very much a novice and am trying to use the mapping tool to help me better understand and see how far off the curve is. Based on my wideband I am not very close to what is commanded.
A9P computer with moates quarterhorse installed.
Thank you for any help you can provide.
alollich
Re: AFR_ERROR
Post by alollich » Wed Mar 21, 2018 3:32 pm
I spent time reading the help sections in EEC Analyzer, changed some of my logging selections and figured out what I was doing wrong. It now calculates slopes and breakpoint.
