software update question
TRBOGT
Post by TRBOGT » Fri May 11, 2018 7:15 pm
Its been a long time since I have updated BE software. I'm running Version 2012 Build 26. I may have to do some tuning this weekend and I was wondering if I need to update the program before I start. Last I remember my datalog was freezing up. I'm not crazy about updating software unless its absolutely necessary. will the update fix the datalog from crashing ?Thanks
CAR #1
1989 Mustang GT FRPP Boss block 302ci /76mm Precision Turbo/ TFS heads/1.6 rockers/ custom turbo cam .565 lift/ 80lb FRPP injectors/spyder intake w/ elbow/80mm Holley TB /slot style MAF/ AOD w/3.27's / Innovate LC-1/ GUF1/ QH tuned with BE & EA.
CAR # 2
1989 Mustang Coupe/ 302ci /Vortech S trim supercharger/ TFS heads/ 1.6 rockers/ Motorsport X cam/ 30 lb Motorsport inj./ BBK SSI intake /BBK 75mm throttle body /80mm C&L tuner tube/ T5, 3.73's/ Innovate LC-1/ GUF1/ QH tuned with BE & EA
Re: software update question
Post by jsa » Sat May 12, 2018 9:43 am
It is pin the tail on the donkey.
Back up your BE install directory, then upgrade. If it goes south restore the backup.
2fast4u
Post by 2fast4u » Fri Aug 31, 2018 7:07 pm
how did you make out ?
88 GT - D.S.S 331 - Holley SysteMAX II upper & lower - 05+ Slot Style MAF - Underdrives - 70mm Throttle Body - Comp Cam XE274HR - MAC LongTubes - 30lbs Injectors - 255lph Fuel Pump - MSD 6AL - 4:10's - 31 Spline -Tremec T-5 -TwEECer RT- BE & ECC Analyzer - A9S
