Throttle status...
Fordpowered90
Throttle status...
Post by Fordpowered90 » Sat Jul 07, 2018 7:36 pm
what logs the change in ct/pt/wot? my tune just reads closed throttle the whole time, what can be changed to make it register?
90GT, 408ci, TFS Box-R, 90mm TB, Edelbrock Performer RPM Heads, XE282HR CamShaft, SCT BA-3000 MAF, 60lb Injectors, 9psi Powerdyne, Shorty Headers, X-Pipe, 4.10 Gears, Moates QuarterHorse, Binary Editor
skunk
Re: Throttle status...
Post by skunk » Sat Jul 07, 2018 10:53 pm
What software are you using? If using BE double click on the TS guage. Another window opens set enumeration and 3. Near the bottom you will have Value and Text. Set the values from top to bottom as -1, 0, 1 and Text top to bottom as CT, PT, WOT. If your using TunerPro.....sorry I can't help.
Fordpowered90
Post by Fordpowered90 » Sat Jul 07, 2018 11:30 pm
sorry its BE, thanks for reply.
