BE Token Reset
BinaryEditor and EEC Analyzer are both packed with awesome features, but if you can think of another cool feature to aide in EEC Tuning or some improvement to an existing feature, cough it up here.
Moderators: cgrey8, EDS50, 2Shaker, Jon 94GT, 86GT
kylixrd
BE Token Reset
Post by kylixrd » Sun Oct 14, 2018 1:19 am
Hello,
Is there a way to clear a BE token and associate it with another eec? I built a bench programmer so I can read and flash an eec outside the car. While testing it with the Quarterhorse, I wrote an image to it and it consumed a token. Since the test eec isn't the actual one on the car, I cleared the QH. Now I cannot push any more tunes to the QH even if I connect back to the test eec. I can see in the token log the test eec, but it is now dead. This system seems rather brittle and easy to inadvertently shoot oneself in the foot.
kylixrd
kylixrd
Re: BE Token Reset
Post by kylixrd » Tue Oct 16, 2018 6:59 pm
Ok, got it taken care of. Things are now back up and running.
Re: BE Token Reset
Post by motorhead1991 » Tue Oct 16, 2018 9:05 pm
That's weird... I have a tokenized tune and some open source ones and have never run into that. I've cleared, read and rewrote the tunes a few times.
kylixrd
Re: BE Token Reset
Post by kylixrd » Thu Oct 18, 2018 9:51 am
I suspect the issue may have been that I never actually saved the original tune. I was only testing that BE could communicate to the EEC on the bench power-supply/programming harness I'd just built. It's all working now and can communicate with the devices I need to.
