CZAJL XDF for TPRT (93-95 Lincoln Mark VIII)
Cobbled a few up. One accesses everything, the other accesses limited stuff but can tune most of what you'd need.
Feel free to inquire.
CDBA4 - DONE
CDAN4 - DONE
CMBA0/CMAI3/6/7/9 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
ironmanisanemic
Re: CZAJL XDF for TPRT (93-95 Lincoln Mark VIII)
I am interested!
1989 Ford Bronco:
1995 Ford Mustang GT
Can't seem to attach it but here is the direct link.
**EDIT** SEE BELOW POST FOR ATTACHED XDF
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
Try to attach it again.
I logged in to see if *.xdf was an allowed extension, and it wasn't on the list, so I added it. Hopefully that will allow *.xdf files to attach now.
Thanks!
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
I usually zip them in with the binary, but this is still appreciated
I believe I've updated it since the one you saw on efidynotuning too.motorhead1991 wrote: βThu Feb 07, 2019 11:16 amI usually zip them in with the binary, but this is still appreciated![]()
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
I wouldn't doubt that. Mine is constantly updating as I find things, in fact I'll probably release another update on the 10th.034v wrote: βThu Feb 07, 2019 2:23 pmI believe I've updated it since the one you saw on efidynotuning too.motorhead1991 wrote: βThu Feb 07, 2019 11:16 amI usually zip them in with the binary, but this is still appreciated![]()
Here is a 4.10 starter BIN
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
