No Signal To Fuel Injectors
Locked
neonbeef
Post by neonbeef » Fri May 17, 2019 4:18 pm
Hello All:
I am not getting a signal to my fuel injectors.
This is a new project using a AHACB strategy from Sailor Bob. The truck uses the Fiveology Racing Stage 2 (reman EEC IV PCM/76mm MAF/Overlay Harness). It uses an MSD 6A ignition box. I have not started the truck yet as I have had some issues with the fuel system. Speaking of, the fuel pump is on it's own circuit now (the pump, relay, and circuit breaker).
Also, there is no purge canister, HEGO, EGR (the exhaust is not on the truck) or thermactor pump. The last two will not be added ever as I do not live in CA.
Which scalars should I be checking into at this point?
I suspect the computer cannot see the distributor and therefore is not sending the signal. But, I may be wrong.
See below for more information.
If someone would like to see my file, let me know.
Be well, and have a great day!
Wayne
1992 Ford F150 Std Cab/Flareside/4X4/Toughened E4OD
393 Stroker/Eddie 5.8 EFI Intake and Heads/Fiveology Racing 76mm MAF & WAY1/Comp Cams XE 274/Eagle Rotating Assembly Kit/Green Giant Injectors/MSD Plugs, Wires, Distributor, 6AL Spark Box/9.9:1 compression
AHACB Strategy/Moates QH/BE - Core Tuning
neonbeef
Re: No Signal To Fuel Injectors
Post by neonbeef » Sat May 25, 2019 11:53 am
Does anyone have a clue?
Wayne
Post by cgrey8 » Sat May 25, 2019 4:13 pm
I responded to your other thread.
viewtopic.php?f=1&t=22839
There's no reason to create 2 threads for the same problem.
Locked
Users browsing this forum: No registered users and 32 guests
