Hi everyone, I am hoping someone can help me out with this.
Is there a way to enable the Data output link for pin34 for my trip computer when using A9l with GUFB?
I am using an Australian EECIV (1DEB) and the A9l programming to control Two Speed Thermo fans which I have installed following the guide at viewtopic.php?f=1&t=2957 on this forum
The thermo conversion works great however I have noticed that my Tripcomputer no longer correctly records my fuel economy.
As far as I can tell the the A9l doesn't have it active and there is no listing in the GUFB definition for how to turn it on or adjust it.
Any advice on how to get it working would be appreciated, Thanks.
Looking for DOL in Gufb for tripcomputer
Ford Falcon Eb v8 1992 Auto, 1DEB running A9l.256k with Ti Performance J3 chip
Re: Looking for DOL in Gufb for tripcomputer
Hi Mate,
I thought the GUFB tune ran the trip computer, when loaded into a EB ecu.
My brother has an XF Fairmont Ghia with NC Fairlane 5.0, and I had a GUFB/A9L running in it for a while when I was testing some things , and I was sure the trip computer worked.
I will have a look at swapping the A9L (1DHA currently in it) back into it on the weekend, and see what happens.
I have a couple of EB/NC trip computers here as well, I may wire one into my XF Wagon that has a 5.0 running A9L and see what that does.
I also have a couple of EB Series 1 and 2 EECs, to try out.
I will get back to you as soon as I have tried them.
I have the A9L strategy running on a 2DCA ECU in my ED XR8 Falcon and to me the output looks as though it is outputting gallons / 100km rather than Litres / 100km on the tripmeter
The following may be complete drivel and I have not had an opportunity to try it out yet.
In the GUFB Strategy document the DOL section has the following formula:
There is a post on efidynotuning.com which references the address to change 0x4cd5
http://forum.efidynotuning.com/viewtopi ... tripminder
7804.19 = (48000 pulses/gal)/6.15 lbm/gal, pulses/lmb.
At that address you will find that the value does not match 48,000, it is 8,850 which is 48,000 / 5.
So you get the hexadecimal values of 2292 EF22, where the 2292 is the value we are interested in.
Searching the 256kb version gives an address of 0x26DB1 (or about that)
So if we do the following:-
3.78541178 US Gallon
8,850 / 3.78541178 = 2,337.92266584 = 2,338 = 0x0922 in Hex
Replace the 2292 with 0922 and the tripmeter "should" be pretty close for Litres / 100km.
Cheers.
Cheers.
EEC-IV 1994 ED XR8 Sprint 302W, BTR 4spd auto, Crane Cam 220/226@0.50 0.53/0.54 lift w/ 1.7rr, 108 LSA, stock 65mm T/B, stock 70mm MAF, Edelbrock RPM Performer II intake, stock 24lb inj, 9.7:1(?) comp, Edelbrock E-Street Heads (better springs), Advanced Headers, Tuner Pro RT & J3 Chip & burner supplied by TI Performance, 2DCA/2DDA
Yeah I did test it out and the A9L is putting an output on pin 34, but it did not appear to be right.
I was going to look into it a bit more but have not had time.
Looks like f4ll3n has already worked it out.
Sorry for the late reply, just to update, i tried changing the address as suggested but nothing changed, I've also tried amounts as low as 50 and double of the original but it appears to make no difference at all in the calculation of fuel economy, its always averages out to about 3.9-4.0 L/100km.
Just to confirm I hadn't damaged the ecu while soldering I removed the chip and the fuel economy works as per normal.
While driving in gear the instant economy is about 1L/100km but the number does go up when taking off.
So either this is not the correct address or maybe the Australian trip computers handle the output differently?
Tvrfan has this in his disassembly;
Log RC6, see what you get.
Ox4cd5 looks like the address of the fudge factor.
Update_flDOL:
4cca: 9b,74,ce,00 cmpb R0,[R74+ce] # Fuel Sum High
4cce: d2,2c jgt 4cfc if (0 > Fuel_sum_h) return; }
4cd0: af,fc,31,14 ldzbw R14,[Rfc+31] WR14 = InJPP; # No of injectors fired by each output port.
4cd4: 6d,7c,1e,14 ml2w R14,1e7c LR14 = R14 * 1e7c;
4cd8: 01,18 clrw R18 R18 = 0;
4cda: a1,00,02,1a ldw R1a,200 R1a = Mult_bp311;
4cde: 8c,14,18 divw R18,R14 R18 = LR18 / R14;
4ce1: fa di disable ints;
4ce2: a3,74,cc,14 ldw R14,[R74+cc] R14 = Fuel_sum_l;
4ce6: af,74,ce,16 ldzbw R16,[R74+ce] WR16 = Fuel_sum_h;
4cea: 8c,18,14 divw R14,R18 R14 = LR14 / R18;
4ced: c3,74,cc,16 stw R16,[R74+cc] Fuel_sum_l = R16;
4cf1: c7,74,ce,00 stb R0,[R74+ce] Fuel_sum_h = 0;
4cf5: 09,01,14 shlw R14,1 R14 <<= 1; ## R14 *= 2
4cf8: 64,14,c6 ad2w Rc6,R14 Dol_count += R14; # add to Data Output Link Count
4cfb: fb ei enable ints;
4cfc: f0 ret return;
Thanks for the help, Ox4cd5 is the correct modifier, f4ll3n's post had me confused as he said Ox4cd5 but said the hex to change was 2292 EF22, where the 2292 is the value to change so I was modifying that.
Now I'm changing Ox4cd5 and the trip computer is working correctly, though it appears to not be a direct conversion from imperial to metric to work with the Australian trip computer
I'm in the ballpark anyway so I can dial it in now.
Thanks for confirming.
