Gwais
lq4 408 build questions
Post by Gwais » Wed Feb 12, 2020 11:05 am
hey guys, what would be the best 408 ls stroker kit to go on my lq4? also what cam heads? its going in a 1990 s10 with a 4L80e being built, what should I look for when building it? what HP should it make? any help will be great!
ChsReb
Re: lq4 408 build questions
Post by ChsReb » Fri Nov 12, 2021 5:54 pm
Intended use?
Ford 408 in a Chevy S10?
