02sensor delete in a drag only car
New to tuning ,my first efi drag car, 302, 5 speed, RPM heads and intake , xe274hr cam , l.tube headers, can I deleate the 02s? i have a Holly wideband to monitior afr, thoughts?
Re: 02sensor delete in a drag only car
That should be fine, if you disable them in the tune and force open loop to be safe.
It doesn't really matter whether you disable them or not if you force Open Loop. Only Closed Loop fueling is going to "look" at them during normal runtime.
KOER tests might would still care, but my guess is a dedicated drag car isn't going to be doing a lot of KOER tests.
