I think it's from 2002 Mustang 3.8 with 70 mm housing
I found calibration for A9L, W4HO and F-series from EEC Analyzer, but this MAF used for E-series and 02 mustang 3.8
From my understanding, that is incorrect. The transfer (conversion as I am used to saying from my job) is the output of a particular sensor-housing combination. A different air filter will not alter the curve, though it may alter the relationship between throttle and airflow.ChsReb wrote: ↑Fri Aug 13, 2021 9:34 am Here is a place to start: http://efidynotuning.com/. He has wiring Diagrams there to under "MAF". Look under "MAF transfer curves".
Remember a MAF and/or MAF curve is only a "drop in" for the same PURE stock vehicle it was installed in, and even then the older (My Stock '95 Curve was a joke.) Stock MAF curves were way off. (Closed Loop is a great Fudge Factor for a "One size Fits All" MAF .) Anything you do to change the way air moves through the engine alters the MAF curve. Even going from a stock air filter to a K&N will alter the curve. (In this case it leans it out. The engine breathes easier.)
I'm curious to know the how on this too. I'm not doubting it's a real phenomenon. I'm just curious how it manages to pull this off.
Measuring airflow on the front of an engine is far from an ideal environment. Whether there's turbulence or not, the pulsed aspect of intake air means that the sampling rate on the sensor has to be far higher so the readings can be averaged.ChsReb wrote: ↑Wed Feb 09, 2022 8:25 pm ...1,) Is turbulence at the MAF sensor an issue. YES, Definitely!! Going back to my HVAC days, we always chose a point to drill the hole for a Pitot tube or Hot wire, 8-10 duct diameters down from the nearest turn upstream and three diameters from the nearest turn down stream. We can't do that here. Not enough room under he hood...
I'm not sure how much smog pumps add to the mix. Fortunately most people on this forum are probably taking those off or disabling them at the very least. Watching the O2s & WBs are our only way of detecting inaccuracies with fueling. But I don't know how useful they are at gleaning any conclusions about the presence or affects of reversion. Reversion creates pulses that are at the frequency of the engine RPM x the number of cylinders / 2. Even at relatively low RPMs, that's still way faster than stock EECs and datalogging devices can sample at to "see" the waves of reversions on the MAF.ChsReb wrote:...2.) Is reversion an issue? Probably! Especially with a stock smog pump. I dunno how to check for this except for watching the O2 sensors...
I'm going to be a bit nit-picky and pedantic here, but when talking technical issues, it is important to be as accurate as possible.ChsReb wrote:...3.) In my case I bought a slot MAF and a housing. The slot MAF knows velocity. It doesn't know how big of a housing I have installed it in until I scale my MAF. The MAF sensor has a Temperature sensor. Using Temperature and Velocity the computer knows air density and Mass Flow per unit area...
This is true for most analog sensors whether it be voltage, airflow, light, or anything else. Most sensors are more accurate when there's "more" of whatever it is measuring to measure. The company I work for differentiates itself in the Industrial HVAC industry by making VAV controllers with a MUCH more expensive differential pressure sensor than most of our competition so that our controllers operate more accurately at low-flow conditions.ChsReb wrote:...4.) Every sensor (Computer, Automotive, HVAC, Process) I've ever used is most accurate in it's upper measurement range and least accurate at the lower limits of it's range...
Very true. I recall some mfgs guide the throttle cable around a cam mounted to the throttle blade shaft so that movement of the throttle at low-flow conditions doesn't move the blade as much as the same throttle movement at higher airflow positions. That makes off-idle control of the engine RPM so much easier to control. With modern throttle-by-wire, they can compensate for this in far more sophisticated ways than a cable-cam.ChsReb wrote:...7.) Single blade throttle bodies are extremely NON-Linear air flow controls. In my HVAC days, I've seen slightly cracked parallel Dampers flow 10-15% of total flow and a 40% open blade flow upwards of 70% total flow...
This is one of those areas where my experience has been so radically different than most others here on the board. Both sets of injectors I've ever had to tune for, the stock values I used were trash. I heavily relied on EEC Analyzer to help me tweak my Injector Slope/BP values. So while it may not be recommended for the average person to go messing with those values without a clear understanding of what they are, I would always recommend someone at least check their Slope/BP values against EA just to see how close their values are to what the datalogs are showing...particularly if they've already paid for the EA license. It's like why not?ChsReb wrote:...9.) Could you adjust fuel by altering injector settings? Yes, but I wouldn't recommend it. Injection accuracy at low flows my be lacking as is low flow accuracy across the MAF...
I've never had this experience with an air filter change. The only difference I've ever seen is increase in HP due to less resistance to airflow at the higher end. At lower flow conditions like cruise, the throttle plate is already restricting airflow. The resistance a dirty or less-than-optimal filter might add is going to be minuscule compared to the resistance the throttle plate is applying to the airflow. But the conditions on the engine should not have changed. The engine needs X amount of air/fuel to push the vehicle a certain speed. I'm not seeing, logically, how a freer-flowing filter alters the engine's need for air/fuel or even eases it's burden in any way that would improve its efficiency. Lets say a dirty filter was causing less air to flow. This just means the throttle plate would have to open a little wider. A cleaner filter would just require the throttle plate to close more to produce the same airflow to the engine. But from the engine's perspective, the resistance necessary to result in the airflow required to produce the power needed is the same. Likewise the intake manifold pressure should be the same at those same cruising conditions. So like I said, I'm just not seeing where the increase in efficiency to account for an improvement in fuel economy came from.ChsReb wrote:...10.) I put a K&N on the wife's 4 banger Honda Accord and picked up 2 MPG! Honda's use differential pressure for air flow calculations. My contention here is I improved the engine's volumetric efficiency...
Here are the ones I agree with:ChsReb wrote:...11.) OK so why alter a MAF curve in the LOWER Range?..
As for my setup, it's probably not as dialed in as yours. But I'm also not working with the same caliber of engine. I went into my build knowing the highest HP I would possibly make would be 300hp. And I MIGHT be 270hp at the crank on a good day. But with high compression, 3.27s, lean-tuning at cruise, and a very torque-oriented build, I'm roughly 25MPG on the road (65-75 MPH), 20-22 on the daily commute if I keep my foot out of it. Keep in mind this is a relatively heavy and boxy shaped truck, not a sleek sports car. Without dropping the clutch, it can break the tires loose in 1st. But that's the only gear it can do that. There are limits to what stock ported heads and intake can do.ChsReb wrote:...B.) I'm adjusting for MAF Sensor low flow errors.
C.) I'm adjusting for Injector low flow errors. The bigger the Injector the greater the low flow errors.
D.) I'm adjusting for errors in ITHBMA. LOAD induced or calibration induced.
E.) I'm adjusting for EGR errors or leakage. (If Present.)
F.) I'm adjusting for Smog Pump (If Present) flow Reversion or general exhaust gas reversion.
G.) I'm adjusting for MAF air stream turbulence errors.
I looked at each of these and they seem to detail the purpose and point of PCV correctly. I don't see that anybody has disagreed with how PCV system works that would give you "contention."ChsReb wrote: ↑Fri Feb 18, 2022 8:13 am...As to my contention on the PCV valve, from Wikipedia: https://en.m.wikipedia.org/wiki/Crankca ... ion_system
From Summit Racing: https://help.summitracing.com/app/answe ... alve-do%3F
From an Auto repair site:
https://www.camarilloindy.com/what-does ... 020-09-16/
Users browsing this forum: Bing [Bot] and 118 guests
