bad86capri
Tuning the 03/04 Mach 1
Post by bad86capri » Thu Jul 28, 2022 11:30 am
So im in process of building a stock 4.6 4v for a mach 1. The engine will be stock except for 01 cobra cams on the intake, which are stock just a little bigger than the factory mach cams, longtube headers and a 90mm lightning MAF. What all is involved in tuning the 4v stuff? I'm used to tuning to foxbody cars. Any help would appreciated!
1986 Capri, Twisted wedge heads, Anderson B3 cam, RPM2 intake, 80lbs injectors, longtube headers, Holley Terminator X,
2003 Mach 1 ZYA2, longtube headers, 90mm lightning MAF (eventually), 3650 trans.
FinnCobra
Re: Tuning the 03/04 Mach 1
Post by FinnCobra » Sat Jul 30, 2022 2:44 am
I have Eaton swapped mach1 engine, and this ecm/strategy is one of the hardest to get working. In my case, big injectors and maf make it difficult. Even terminator has scaled down calibration from factory, and it has only 39 lbs injectors, mine are 54. Your mods are so small, that you should have no problem. Start with original maf.
https://www.auto-huolto.com/texelectric
bad86capri
Post by bad86capri » Thu Aug 04, 2022 7:08 am
Im going to follow your advise and start with everything stock except the headers and go from there. im really considering using deciphas FBGIO bin, for one i like tunerpro better than BE and hes done a lot of work to the bin help simplify things a bit.
Post by EDS50 » Mon Aug 08, 2022 6:48 pm
I think the hardest thing to tune in these cars is the knock sensors without shutting them off in the tune and some of the idle parameters.
2003 Mach 1 - CoreTuning RYAK1/ZYA2 QH Tuned, Borla Atak Cat Back, Long Tubes/Off Road X-Pipe, Twin 65mm TB, JLT CAI, ICT Billet Intake Spacer, BMR Tubular Front suspension, Eibach Pro Series Plus Suspension, Steeda Adj. Upper/Lower Control Arms, QA1 Bump Steer, Steeda Short Throw Shifter, 315/35/17's.
bad86capri
Post by bad86capri » Tue Aug 09, 2022 10:57 am
the mark viii engine has the factory knock sensors but ive not researched it to see if theyll work with the mach.
Post by EDS50 » Tue Aug 09, 2022 11:12 am
My mach has 2 knock sensors that can be tuned.
bad86capri
Post by bad86capri » Wed Aug 10, 2022 10:13 am
So after research yesterday ive determined that im going to need to get threaded inserts that adapt m12 to m8 threads to run the newer mach style knock sensors or delete them and shut them off in the tune.
Post by EDS50 » Wed Aug 10, 2022 10:20 am
You can turn them off completely and just be very mindful of your timing.
Users browsing this forum: No registered users and 52 guests
