Hey guys, been a while. Hope everyone is doing alright.
Car was dialed and running great, had some sluggish hego behavior and wanted to replace them, they were 4 years old. I discovered the DY606 (bosch) hego is no longer available. I tried the aftermarket Bosch hegos and they literally died in weeks.
Bought the DY605 (NGK I think?) supposedly direct replacement for DY606 and installed them.
Now my AFR gauge reads lean 17 at idle, and KAMRFs are pulling fuel and commanded AFR is around 15. Adjusted the lower MAF and it just doesn't seem normal.
At driving speeds AFR is stoic and normal, this issue is only at idle
Is it possible the behavior of these Hegos are different? They are supposed to be direct replacements.
Here is what I've tried so far:
I set bias to all zero with no improvement.
I tried a rich bias at idle but not much improvement.
I was going to try raising the hego switch point up from .423
Any help or ideas would be appreciated.
switched hegos from DY606 to DY605, now lean idle.
331, 34lb Ford racing injectors, RPMII intake, 75mm TB, AFR 185 heads, AOD with 3200 stall, custom cam 600/605 lift 224/231 @ 0.050, 1 5/8" long tube headers, 2.5" x-pipe
Mustang Dyno - 344 Torq, 359 HP
Users browsing this forum: Google [Bot] and 108 guests
