Guys,
have just released latest SAD, version 5.0.1 to github/EEC-IV-disassembler.
Have added a some new features and done a big tidy up. Most likely still some bugs, but I want you guys to play with it and give me feedback.
This version has new syntax with math calculations and multi bit fields are supported. Can also use a field more than once for printing offsets and such. (old syntax still supported, so should still work with existing command files etc.)
SAD version 5 (alpha)
Re: SAD version 5 (alpha)
Thank you for your continued effort.
jamie from oz
Sad 5.0.2 the drag and drop in windows is working now. Thanks.
Have a couple errors in _msg but probably from my _dir file syntax. I will check further.
Thank you for your excellent work with sad and your explanation of the process .
(I have also been following along on some of the disassemble process on efidynotuning forum)
V5.02 does have bugs, so if it works for 4.12 or 4.07.16b, it might not be your dir.
You can add these to your 6DBD dir and cmt if you don't have them already.
DIR
CMT
DIR
SYM 464 "EIGHTHS_REM" #Y #
SYM 465 "SECS_REM" #Y #
SYM 466 "LOOP_TIME_EXT #Y #
SYM 468 "LOOP_TIME" #W #
9599 # [468]
959E # [466]
95B7 # [468]
95BB # [466]
95C2 # [464]
95CC # [464]
95DA # [465]
95E7 # [465]
Yep, there's a few more things screwed up than I thought.
Thanks to jsa for his testing - excellent stuff as always.
For all of you, report anything that looks wrong, and I will check, although I have quite a list already so it may not be immediate...
Some stuff in V5 is also kind of experimental (fields within fields for example - you *do* get these in some structs ), so use latest V4 to confirm, I'm 99% sure that works....(never 100, can always be a sneaky bug lurking somewhere...)
jamie from oz
Yes was only with 5.0.2jsa wrote:so if it works for 4.12 or 4.07.16b, it might not be your dir.
Have added the items to Dir and Cmt. Thanks
Re: SAD version 5.05 (alpha)
I have some branches using JLEU where the printed output is rather obtuse.
Zero will never be greater than zero...yeah it's an artefact of the PSW setter not being captured.
From CARD.
In other cases where SAD has not been able to identify the PSW setting code, something like CY = 0 is printed.
Referring to the software manual, JLEU will jump if the carry flag is zero or the zero flag is one.
For the continue case above, could SAD print something like;
It could be two lines, one each for C and Z.
Using the PSW command continues to work in this version, giving the expected output. So two thumbs up for that.
DIR
LST
From CARD.
341b: af,76,e9,42 ldzbw R42,[R76+e9] wR42 = [dc3c];
341f: 29,2b scall 354c Sub_354c ();
3421: d1,03 jleu 3426 if (0 > 0) {
# SCall from L33F7 Sub2ea1
# SCall from L341F Sub2ea1
# SCall from L3508 Sub2ea1
# SCall from L3530 Sub2ea1
Sub354c:
354c: 01,32 clrw R32 R32 = 0;
354e: 8c,34,30 divw R30,R34 wR30 /= R34;
3551: 07,42 incw R42 R42++;
3553: 88,42,30 cmpw R30,R42
3556: f0 ret return;
3421: d1,03 jleu 3426 if (C_PSW = 1 & Z_PSW = 0) {
DIR
PSW 33F9 3553
PSW 3421 3553
PSW 350A 3553
PSW 3532 3553
3417: a3,70,32,30 ldw R30,[R70+32] R30 = [4b2];
3421: d1,03 jleu 3426 if (R30 > R42) {
Users browsing this forum: No registered users and 45 guests
