IronLotusBKO
Injector scalars
Hey guys, I installed 24lb injectors in place of my 19 lb ones on my 95 bronco 5.0, i know I should adjust my breakpoint and probably my minimum pulse width as well correct? Is there any kind of starting parameters for the swap? Thanks guys! I’m really new to this, really sorry if this is a dumb question. I saw a post that was kind of a beginner where to start post, but I couldn’t make heads or tails of the numbers.
Btw I am tuning with a Tweecer and use vex1 strategy. It’s a ca truck so it’s a mad system.
95 Bronco 306, rpm performer heads, shorty headers, bbk 56mm throttle body, 24lb injectors, forged internals. Tuned with Tweecer VEX1 strategy
Re: Injector scalars
There's a lot of resources online, like Mike's website at EFIDynoTuning.com, but yes, an injector swap generally requires adjustment to the following functions and values:
- Injector breakpoint
Injector high slope
Injector low slope
Injector's battery voltage offset curve
Injector timing (optional and not really tunable without datalogging anyway)
IronLotusBKO
Ok cool I’ll look for the data. They’re denso ones that came out of a cobra. I’m sure I can find them somewhere. I’ll check that site now I appreciate it
IronLotusBKO
Ok, so I believe I found the data I need but it’s in a different format than I’m used to. Does Tweecer have a different format than others?
What format is it in? Is it just a unit conversion issue you're dealing with?
IronLotusBKO
Yes I believe so, I’ll go back and find it. I haven’t had a sec to deal with it in a few days
IronLotusBKO
So I’ve been busy as heck and finally got back around to tuning. I use a Tweecer and this is the format I found but don’t understand
Multiply injector slopes by 3600. The breakpoint is 2.219IronLotusBKO wrote: ↑Wed Dec 04, 2024 8:58 am So I’ve been busy as heck and finally got back around to tuning. I use a Tweecer and this is the format I found but don’t understand
IronLotusBKO
Paulie wrote: ↑Thu Dec 05, 2024 4:23 pmMultiply injector slopes by 3600. The breakpoint is 2.219IronLotusBKO wrote: ↑Wed Dec 04, 2024 8:58 am So I’ve been busy as heck and finally got back around to tuning. I use a Tweecer and this is the format I found but don’t understand
Awesome! Thank you so much!
IronLotusBKO
Still a bit confused on Injector's battery voltage offset curve… is there a post anyone can link that explains well?
The values are slightly different because BE rounds the numbersIronLotusBKO wrote: ↑Wed Dec 11, 2024 12:04 pm Still a bit confused on Injector's battery voltage offset curve… is there a post anyone can link that explains well?
IronLotusBKO
I guess i just don’t understand how I should adjust it and why
IronLotusBKO
So I was just about to change the breakpoint and slopes on the Tweecer, (stock tip1 breakpoint is 0.000149) it’s telling me the max can only be set to 0.001 so I’m thinking i need a different format?Paulie wrote: ↑Thu Dec 05, 2024 4:23 pmMultiply injector slopes by 3600. The breakpoint is 2.219IronLotusBKO wrote: ↑Wed Dec 04, 2024 8:58 am So I’ve been busy as heck and finally got back around to tuning. I use a Tweecer and this is the format I found but don’t understand
IronLotusBKO
Anyone have any insight?
.0002219IronLotusBKO wrote: ↑Wed Dec 11, 2024 1:47 pmSo I was just about to change the breakpoint and slopes on the Tweecer, (stock tip1 breakpoint is 0.000149) it’s telling me the max can only be set to 0.001 so I’m thinking i need a different format?Paulie wrote: ↑Thu Dec 05, 2024 4:23 pmMultiply injector slopes by 3600. The breakpoint is 2.219IronLotusBKO wrote: ↑Wed Dec 04, 2024 8:58 am So I’ve been busy as heck and finally got back around to tuning. I use a Tweecer and this is the format I found but don’t understand
IronLotusBKO
Awesome! Thanks I appreciate it
Users browsing this forum: No registered users and 40 guests
