Datsun510
Output Shaft Limiter Stages?
Post by Datsun510 » Sat May 04, 2024 3:42 pm
Can anyone tell me what these are used for?
I found these in my ‘Scalars’ and under ‘Limiters - Ignition and Speed’. The units are in rpm. The definition file doesn’t mention its purpose.
Output shaft (4x4) limiter stage 1 Disable
Output shaft (4x4) limiter stage 1 Enable
Output shaft (4x4) limiter stage 2 Disable
Output shaft (4x4) limiter stage 2 Enable
Output shaft (4x4) limiter stage 3 Disable
Output shaft (4x4) limiter stage 3 Enable
Coupe, 5.0L w/GT40 Heads, Vortech V-3, Explorer Intake, Steeda Cam, BBK Shorty Headers, 65mm TB, 80mm MAF, 34lb Injectors, Aftermarket T5 SHD, 3.73 Gears, Mongoose-Plus, Tuned using BE & EA, JFX0
AuroraGirl
Re: Output Shaft Limiter Stages?
Post by AuroraGirl » Sat May 04, 2024 8:26 pm
4x4 output shaft limiter ,to me, sounds like it could be related either to a PTO or to the front shaft. If you have it going to fast, bad things could happen, and that RPM wont be engine RPM because of gearing and choice of tcase gear. so it may have progressive cutting of fueling or maybe it does something else. but not sure
1996 F150 4.9l I6 E4OD 2wd 3.08 Ford 8.8 rear
Datsun510
Post by Datsun510 » Sat May 04, 2024 9:32 pm
Aurora Girl,
That explanation sounds good to me. I don’t think these ever get changed from factory setting. Thanks
Users browsing this forum: Google [Bot] and 94 guests
