blacksaleen95
Foxbody EEC-V
Post by blacksaleen95 » Sun May 12, 2024 1:16 pm
Looking for some guidance as I've found limited info in my searches...
Current setup: Boner Stock 92 Foxbody (A9P), '03 4R70w (microshift)
Plans: EEC-V Swap retaining '03 4R70w trans electronics, and factory 92 ignition (TFI/Dist)(I know it's trash)
I'm aware that the DIS is a better setup, and plan on using it on some future projects, however I'm just trying to get my feet wet with the QH on a stocker setup and play around with the 4R70 and tuning parameters before I dive into something that warrants the DIS.
In my searches I've seen the '96 F150 5.0 ECU suggested, but I'm not clear if it will support the requirements I have for the transmission. (would prefer to retain '03 trans electronics).. Before I go on my search for this ECU, I just want to confirm with some of the more knowledgeable guys that this is possible and that ECU is my only option.
Any suggestions or input is appreciated!
Jim
Users browsing this forum: Bing [Bot] and 31 guests
