boss96
Dataq a/f on Calcon / UltimaSerial has expired
Post by boss96 » Fri Mar 05, 2004 8:24 am
Not sure if this is the right forum but here goes. I am able to datalog a/f ratios now on calcon but after awhile it is giving me a message "unregistered version of ultimaserial" or something to that effect. You have to click "ok" to use calcon each time.
This may be stupid but I assumed that when I purchased the Dataq hardware/software that I would be good to go.
Anything I missed?
Bob
KB_Stang
Post by KB_Stang » Fri Mar 05, 2004 10:43 am
I also have the same issue.
shonut
Re: Dataq a/f on Calcon
Post by shonut » Fri Mar 05, 2004 12:02 pm
boss96 wrote:Not sure if this is the right forum but here goes. I am able to datalog a/f ratios now on calcon but after awhile it is giving me a message "unregistered version of ultimaserial" or something to that effect. You have to click "ok" to use calcon each time.
Anything I missed?
Bob
Mike has an update for this which will be released shortly. I've tested it, and it works.
The Ultimaserial software component bundled into CalCon IS licenced/registered, but from what I gather, if you install the DataQ software after CalCon, it overwrites the licence, and the driver now thinks that it is unlicenced.
The update re-writes the licence information properly, so that that Ultimaserial knows that the installation is licenced (As part of the CalCon software).
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
www.shonutperformance.com
sales@shonutperformance.com
EEC Analyzer User - now with one-step WB-based MAF tuning
http://EECAnalyzer.webhop.net
boss96
Post by boss96 » Fri Mar 05, 2004 1:08 pm
Josh, since I am installing a new hardrive in my laptop today...all I will have to do for now is install Dataq first, then Caledit/Calcon and it will work correctly?
Bob
shonut
Post by shonut » Fri Mar 05, 2004 1:14 pm
boss96 wrote:Josh, since I am installing a new hardrive in my laptop today...all I will have to do for now is install Dataq first, then Caledit/Calcon and it will work correctly?
Bob
We think so, but we are not sure. You can try it, and if it works, then we know what the problem was. However, I don't know if the 'trial' period starts when the software was installed (i.e. it may work on your new laptop hard drive now, but pop up again later ...), or when the software was originally licenced.
Try DataQ first, then A7/8 and let me know what happens. If you still get the error, I'll see what I can do for you ;)
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
shonut
Post by shonut » Sun Mar 14, 2004 10:09 am
O.k., I've been given clearance to relase the UltimaSerial updates.
NOTE - from what I gather, this update only needs to be done if you installed the DataQ software AFTER Calcon. The DataQ software apparently over-writes the CalCon-embedded non-expiring UltimaSerial licence with one that will expire.
If your UltimaSerial is 'expiring' extract the two executables in this .zip and run them in sequence.
http://www.shonutperformance.com/UltimaSerialUpdate.zip
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
Users browsing this forum: Google [Bot] and 24 guests
