2003 cobra spark tables
I am running a turbocharged 4.6 4V in a 1996 Mustang. I am using CDAN4. The engine goes into 6 psi boost at about 2200 rpm and maintains this to redline. The log of "Load vs MAF" shows that Load only gets to 80%. I have modified FN012 to reflect this. I'm running a maximum spark advance of 18 degrees. I have the Spark tables from a 2003 Cobra. It shows the maximum load at 150%. What parameter do I change to get the EEC's calculation of load to reflect the increased airflow produced by the turbocharger? Thank you.
Re: 2003 cobra spark tables
What MAF are you running?
If not stock, did you updated the MAF transfer curve to match the sensor you are using?
'89 Notch, 304(5.0), Novi2K@13psi (currently not installed) TFS heads, TFS Stage 1 cam, Cobra intake, 60lb'ers and Pro-M 80mm, longtubes_x-pipe_flowmasters and more crap that doesnt increase power. 437rwhp@5500(and still climbing)/438rwtq@~4000rpm Tweecer R/T w_BE and EA
I upgraded to a 2003 Cobra MAF and programed the MAF transfer function into the EEC-V. Everything works, but the maximum "Load" is only 80%, so I had to change the spark table to match this. I am asking because the 2003 Cobra spark table shows a maximum "Load" of 150%. I am using 42# injectors.
This pdf is an explainer on load calcs, courtesy of Dan-HM from Yahoo EECTuner group.
Which "load" are you logging?
Thank you.
Users browsing this forum: No registered users and 214 guests
