klondike93
Another new guy
Post by klondike93 » Sun Jan 05, 2003 9:40 pm
Seeing others post an introduction has me doing the same so, hello all!
I just got a TwEECer a couple of days ago and I'm looking forward to playing with it.
My car is a 94 GT, P1SC supercharger, 70mm BBK throttle body, 75mm Granatelli MAF, BBK adjustable fuel pressure regulator and that's about it.
On tap is a Trick Flow intake, MSD 6BTM, FMS 3.55 gears.
So where's a good place to start? After putting the supercharger on it no longer idle's at all so I need to look into fixing this first.
Chuck
Daren Woodall
Post by Daren Woodall » Mon Jan 06, 2003 11:49 am
What injectors and MAF calibration are your using with this combo?
94GT, AFR165, E303, 1.72 RR, GT-40 Intake, 70mm TB, 24lb inj, ProM 75, BBK LT, J4J1, PLX M-300 WB
klondike93
Post by klondike93 » Mon Jan 06, 2003 9:37 pm
Right now it's using the stock 19# injectors, but I have a set of 30# ones ready to go in. As for the MAF it's set up for the 19# injectors. I do have a sheet that came with it, but I don't know what it's for, could you tell me what to use it for?
A question I have is can the TwEECer compensate for MAF set for 19# and using the 30# injectors?
Chuck
93notch
Post by 93notch » Mon Jan 06, 2003 10:20 pm
Yes, just load the generic PROM19 MAF Xfer that we have and then change the hi/lo injector slopes to 30/36 and start tweecing.
To load the MAF xfer, go to the MAF Transfer function on the functions tab and in the lower right hand corner you will see a Load MAF button. Click it and a list of transfers will be displayed. If it does not show a list of PROMxxx then use the Look In section of the dialog to goto:
C:\Program Files\STKR\MAF
Then select the PROM19.
Best regards,
Mike Glover
klondike93
Post by klondike93 » Mon Jan 06, 2003 10:25 pm
Cool, thanks Mike.
Chuck
