IronLotusBKO
Ecu interchangeability
Hey all! Please move this if this is the incorrect place. I have a 95 bronco 5.0 maf, e4od, auto t case. I have come to find lately that major components such as ecus, are hard to locate. My truck has a tip1 in it and I happened upon a very clean truck with a hug0 ecu in it. 1995 5.0 maf, auto trans, but rwd. My question is will this ecu interchange with my current tip1 (with or without tweecing anything?) and if it does what would I look into changing? Also if it will can I use my current tune with vex1? To be clear I want a spare in case mine ever decides to quit
95 Bronco 306, rpm performer heads, shorty headers, bbk 56mm throttle body, 24lb injectors, forged internals. Tuned with Tweecer VEX1 strategy
Re: Ecu interchangeability
The TIP1 ECU (SMD-221 hardware) is not suitable for swapping with a HUG0 ECU (SMD-219 hardware) as they use different transmissions. As a general guide you can use any ECU with the same hardware code but you may require a chip or reflashing to have the correct calibration if the one in the replacement ECU differs greatly.
IronLotusBKO
Would YEA1 (smd-221) be a suitable replacement for the TIP1 with Tweecer?
The YEA1 should be fine.
IronLotusBKO
Okay so I got a better deal on another one also smd-221 but the strategy is DIX0. Assuming I’m solid ?
The DIX0 should be fine too.
Users browsing this forum: No registered users and 54 guests
