Disable Altitude Spark
One can now disable the altitude table, this leaves just the sealevel spark table as the only remaining primary spark table.
The memory location to disable the altitude table is:
0x3713-0x3714 [+0x2000 intel offset] opcode DECIMAL: 484 (stock) to 404
What does that mean ^^^^^ Not clear how to find or disable the altitude spark table....
SRI3850341
disabling all but sealevel
1989 Coupe GUFA / A9S
331 DSS level 10, Vic Jr. heads, Anderson B31 cam, Performer RPM II intake, 60lb Siemens / 340 pump / Pro-m 80,Vortec Strim 10 rib @ 14.7 lbs, Clutch Dynamics dual disc clutch, organic / ceramic, TKO 600, Aussie locker with 3:73's, Motive Ten 31 spline 4 lug axles....
Re: disabling all but sealevel
you'll need to add that scalar to your tuning software
what are you using to tune with?
SRI3850341
BE
If you're using Binary Editor, you don't have to worry about it because it is already in the code. You can disable the alt. spark table using Z_SPKINT. You can disable the WOT spark table with Z_WSPKSW. To disable the base spark table set the load column in FN125 to all zeros.SRI3850341 wrote:Disable Altitude Spark
