Would you guys consider this a high overlap cam? I did some calculations and at 050 lift, I had a -1 degree of overlap. This number sounds to me like I do not have a high overlap cam. However it's certianly doesn't act like it and is pretty "loapy". I'm using 1.7 RRs too.
Comp Cam 284H-R14
Is my cam grind considered "high overlap"
1994 Ford Mustang, Explorer 302 shortblock, TFS TW 170s, TF street burner intake, Comp Cam 1.7 RR, Comp Cam 284H-R14, Stock MAF & intake, Walbro 255lph pump
Re: Is my cam grind considered "high overlap"
calculate the actual crank degrees that the valve is cracked using the .006 number
at 0.006:
59 degrees
This is based off of:
intake: 284
exhaust: 290
LSA: 114
59 degrees
intake: 284
exhaust: 290
LSA: 114
no thats not high overlap thats about common for most off the shelf sbf cams maybe even a touch less
i would consider high overlap to be in the 70+ range
That said, would you expect that I would have the capabilities to dial in fuel at idle? I.e. matching lambse and feedback?
Users browsing this forum: Bing [Bot] and 15 guests
