Cougar281
Determining hardware capabilities
Post by Cougar281 » Fri Nov 25, 2011 10:12 pm
I've heard a bunch of times that often, Ford PCMs don't have all the hardware to drive all functions. For example, Often, a PCM from a manual trans car will not have the hardware in it to drive an automatic transmission.
I'd like to fond out if my PCM has the hardware to drive IMRC's and Knock sensors. Determining if it can drive IMRCs should be easy; add the wires and connect an IMRC motor, set the IMRC open RPM low like 1000RPM and see if the motor moves when the engine hits the target RPM. But how could I determine if it can use the Knock sensors?
1995 Mercury Cougar XR7 -
  • 2002 "Explorer" 4.6L V8
  • "Pink Top" F0TE-D9B Injectors
  • 2002 Mustang GT MAF
  • J-Modded 1999 Mustang GT 4R70W Trans
  • 22c Plugs
  • Cobra Radiator & Fan
  • 255LPH Fuel Pump
  • 180* T-Stat
  • 2004 Mustang GT PTP2 PCM
  • QH v1.6 & BE.
WildGS
Re: Determining hardware capabilities
Post by WildGS » Tue May 31, 2016 7:26 pm
I was curious if you ever found this out? I have an MSE3 with RVAF3 that I am wondering if it will run an IMRC solenoid.
Post by decipha » Tue May 31, 2016 9:20 pm
enable the knock sensor mask and log the voltage, if it stays reporting 1023 then it's missing the knock hardware
same with the imrc, enable it hooked it up and see if it works
Otherwise pop open the case and back trace the pin
WildGS
Post by WildGS » Tue May 31, 2016 11:14 pm
Perfect, will check it out when I get things running
cron
