Mark VIII Tach signal
My buddy has an '00 Mazda B2500 with a '98 Mark VIII DOHC swap. Of course, his tachometer doesn't work, as the Mark VIII used a proprietary databus system to the instrument cluster, where as the truck just had a "tach output" pin on the computer, which is pin #48. Now, I noticed on the Mark VIII computer, pin 48 is unused. Does anyone know if that pin still outputs a valid tachometer signal, despite not being used?
Re: Mark VIII Tach signal
Howdy Leadhead,
On the EEC-V ecu's wiring harness pin #48 is for the tach. I don't think the ecu pits out a "special" signal because I'm using an EEC-V ecu and my AutoMeter tach works.
Easy way to find out is to connect pin 48 to the input side of the tach. The only problem I see is that you're using a V-8 and either a 4 or 6 cylinder tach so your tach will always read wrong.
Paul
Paul
The Mark VII ECU is unique in that it doesn't use the tach output that most EEC-V ECU's have. Pin 48 is hooked up to nothing. It used a Ford databus to communicate to the cluster.
So I don't know if Pin 48 on this ECU actually does anything at all.
you will need to put the missing hardware in the ecu and successfully enable the code in the ecu
i tuned a few ac cobra kit cars that run the 98 mark8 ecu, they all had the tach converter on them
Tach converter? Does it run off an injector wire or something?
I know this is an old post, but I wanted to share my experience, as I was looking for info on this topic and not finding much at all online.
I have a 2000 Lincoln Navigator DOHC 5.4 I transplanted onto my 96 Mustang GT. I’m using the Navi harness and ECU as I wanted true COP, which it already had.
The Navigator had a data bus style instrument cluster just like the Mark VIII, so no tach output wire at pin 48 from the ECU.
I figured I didn’t have anything to lose, so I pinned a wire into the #48 cavity, hooked it to my stock Mustang tach wiring, and it works great!
So, just because there isnt anything coming from pin 48 on your EEC-V harness, that doesn’t mean the ECU won’t output a tach signal!
-Paul
-Paul
