351 to EEC V camsensor ?
I just build up an 351W stroker with an Whipple 2.3 blower that I want to run on an EEC V AOL2
For crank sensor I use Explorer balancer and sensor but Exlporer use 3pin hall cam sensor AOL2 use 2wire inductive.
Is there some that fit ? My idee is to use standard distributor cut all thees exept one and install the 4.6 cam sensor in the distributor housing
Thanks for help Udo
Thanks for help Udo
Re: 351 to EEC V camsensor ?
Are you stuck using that particular computer? There is an EEC-V that supports the TFI distributor a 351 would have came with. The 1996 F-150 5.8 EEC-V is what you'd need.
jep but there the blower I have no space for distributor
Why not just use the 4.6 inductive two wire sensor and make it fit into the Explorer cam sensor housing?
The Explorers came with 2 style cam sensors. I don't know if either of them are what he needs. The older 96-98ish cam sensors were the 1/2 circle type. I don't know what the newer one looks like. I just recall someone discovering that the newer Explorer 5.0Ls had a different cam sensor than the older ones.
The later ones have a single thin tang instead of the half moon.cgrey8 wrote:The Explorers came with 2 style cam sensors. I don't know if either of them are what he needs. The older 96-98ish cam sensors were the 1/2 circle type. I don't know what the newer one looks like. I just recall someone discovering that the newer Explorer 5.0Ls had a different cam sensor than the older ones.
I have ordered an Explorer cam sensor housing at RockAuto when it is here I will see what is better to fit the cam sensor.
Exlorer cam sensor housing ore 5.8 distributor.
Not sure but I think that the oilpump drive is different 5 and 5.8
The 5.8's oil pump drive is slightly bigger, so you'll have to use the 5.8 distributor.
ironmanisanemic
If you want to use a cam sensor in a 5.8, you need 2 cam sensors. You need 1 from an explorer for the housing, and another from a 3.8l for the shaft. Like stated above the explorer used both VR and hall effect sensors, They also had either the half circle and the small tang. I dont think there is a difference operating wise if you use a vr sensor with the small tang, and the VR sensor with the half round or vice versa. I believe it triggers off of the rising edge and ignores the falling edge so the type of shaft shouldnt matter.
1989 Ford Bronco:
1995 Ford Mustang GT
great thanks for that info I try to locate an 3.8 cam sensor... not easy in Germany....
Gowdy,
I built my own from a MSD cam sync plug and a 4.6 cam sensor.
Easy peazy. Works great.
Paul
Paul
ironmanisanemic
If you can still find the cam sync plugs from msd. They stopped making them from what I've seen.Stengun wrote:Gowdy,
Paul
1989 Ford Bronco:
Howdy,
Yes, MSD no longer makes the cam plug but a regular 351W distributor can be modified as well.
Paul
Paul
Have done..
I oredered from Rockauto an Explorer and a V6 sync unit and build one that fit with the Expolrer housing and the V6 shaft and sensor.
Wiring is ready too and I hope to find time to start next weeks
Glad to hear it
Got any pictures to show what you did?UdoFink wrote:Have done..
No sorry,
but it is very simple. Do you nedd partnumbers from Rockauto ?
No, thanks. I've already grabbed a couple 3.8 V6 sensors at the junkyard, guess I need to grab an Explorer one as well. I'll figure it out ... if I ever get around to actually doing this!
it is running starting first time and run great
Thanks for your help
Glad to hear it.
Remember also, that apart from 1/4" vs 5/16" oil pump shaft, the 5.0L block has a smaller hole in the block than the 5.8L. Plus the Explorer Balancer is for a 50oz imbalance engine not 28oz like the 5.8. We do a custom encoder wheel to press fit onto to a step we machine on the back of an aftermarket 5.8 Balancer for this purpose.
