ChsReb
Looking for an OIl Pan Recommendation for a 408 Stroker
Post by ChsReb » Sat Jul 15, 2017 9:54 am
I've been told that stock 351 Windsor pans won't work. (95 Mustang GT Convertible) I'm not building a show car, just a strong street car that probably won't ever see the strip. Is there a JEGS, or Summit Racing Pan available that works or is this MOROSO territory? Any thoughts on the Oil pickup are welcomed as well. I was Looking at Cobra R parts, but just wanted to be sure.
LeadHead
Re: Looking for an OIl Pan Recommendation for a 408 Stroker
Post by LeadHead » Mon Jul 17, 2017 11:24 am
Post by decipha » Sat Sep 09, 2017 11:02 pm
i used a canton 7 qt on mine with the windage tray
Users browsing this forum: Google [Bot] and 40 guests
