Looking for an OIl Pan Recommendation for a 408 Stroker
I've been told that stock 351 Windsor pans won't work. (95 Mustang GT Convertible) I'm not building a show car, just a strong street car that probably won't ever see the strip. Is there a JEGS, or Summit Racing Pan available that works or is this MOROSO territory? Any thoughts on the Oil pickup are welcomed as well. I was Looking at Cobra R parts, but just wanted to be sure.
Re: Looking for an OIl Pan Recommendation for a 408 Stroker
i used a canton 7 qt on mine with the windage tray
Users browsing this forum: No registered users and 29 guests
