venomstang
I had the same problem, try this via a post Mike G. sent me on Yahoo tweecer group:
In the yahoo group tweecer look under files>software updates> for file A9LPL.DBF. Download this file to replace the one in your STKR>DATA folder.
This worked for me.
Good Luck, Happy Tuning!!
This worked for me.
93' Mustang Cobra, X3Z, DSS 331, N/A, 10.8 to 1, AFR 185's, XE274HR, 30lb., Holley Intake, Pro-M Bullet, Dyno'd 380 RWHP, Custom chip by Jerry Wroblewski
blownholley50
tcgrmt wrote:I had the same problem, try this via a post Mike G. sent me on Yahoo tweecer group:
This worked for me.
im having the same problem, at 1st i could just see what the car was dong but could not log, so i downloaded all the new updates and now it will not log the car period, data or regular, any sugestions????????
stangsrule
I am having the same problem with my 92GT with the A9L. Mike sent me the updated file and I just got done trying it but there is no change... I am at a loss as to what the problem is, everything looks like it should work but it doesn't. I am sure it is probably something really simple, it usually is, but I have no clue as to what it is... :? Any more ideas? :)
92 GT with a Kenne Bell Blowzilla, J&S KnockGaurd SMC Alky injection, Edelbrock heads, full exhaust, bigger mass air,TB, injectors etc. , a bunch of suspension stuff, AND of course, a TwEECer!!!
blownholley50
Stangsrule: I thought you were an SN95 owner, the file I sent will not help, I will send you and blownholley an updated payload that the rtupdate.exe fuggs up.
Best regards,
Mike Glover
Mike Glover
stangsrule
I wondered when you pointed out that it was a SN95 file... :D I will give this new one a try and let you know what I find out. Thanks a lot Mike!
stangsrule
calcon not working
I'm new to the tweecer but I've been following emails on the user group in yahoo. Still I'm having no luck. I can download to the tweecer and modify calibrations and see the changes in the way the vehicle runs. However I cannot get the data logging to work. I have the box checked in cal edit and have reloaded the software with and without the update. Still no data logging. I'm running a X3Z processer with an A9L calibration and Windows ME on the laptop. The engine is a stock 1994 351 pickup motor with Cobra intakes , long tube headers and 24lb injectors in an early Bronco. Any help is greatly appreciated.
When you run CalCon, do you:
-- Select the Fox RT Method radio button at the top
-- Click the Start Logging button
If you are doing this already or try this and it still does not work, then email me direct at info@tweecer.com and I will get with you. Please reference this thread and give some contact info.
Best regards,
Mike Glover
Mike Glover
Users browsing this forum: Google [Bot] and 24 guests
