Don 95Vert
Can Calcon LPT/USB co-exist on the same laptop?
I'm using our laptop for my car (TWEECER R/T) via USB. My son (rl) just got a TWEECER parallel. We can't get his to work-it won't read the EEC. And using the correct Lightning binary-it gives an error message when we attempt to download it to the Tweecer. Does the Calcon USB and Calcon LPT each use system files with the same name that are different? If so, is there a work-around so we can do this. I did re-name the STKR folder to STKR USB so when I installed the LPT version it would not overwrite the USB version.
1995 Kenne Bell 5.0 Convertible
11.43/121+ @ 3700#
W4H0 with a J4J1 Cal/CalEdit v.1.20B3
11.43/121+ @ 3700#
They can coexist together -- unlike some humans....
Best regards,
Mike Glover
Mike Glover
twinturbostang
Don't need marriage counseling for your software then eh? :D
www.twinturbostang.com
Don,
I'd like to know what you did to get a good read on your boy's EEC. I have never been able to read the EEC in my car, I have to start with a copy from the Caledit site. It's interesting that he has the same problem with the LPT that I've had. Mine seems to work okay otherwise. Later.
Greg
Greg
'95 GTS lives on in '00 V6 body! 347, J4J1, LPT, 6037's w/Comp Beehives, Extrude honed Cobra, 75mm TB, 87mm Pro-M, TFS Stage 2, 1.7's, 30#r's, LT's, Offroad X-pipe, Bassani catback, and every suspension tweak except for a torque arm.
Don 95Vert
We couldn't read the EEC on his Lightning. Mt '95 with the USB version worked fine.
BTW: I found that the LPT and USB version DO NOT co-exist peacefully. Whne I run the USB version with the LPT version installed, the USB version says the connection is LPT 1.
11.43/121+ @ 3700#
11.43/121+ @ 3700#
Sorry, I should have been more clear. You will have to select a different install folder for each. I usually install the LPT version in STKR_LPT. My bad.......
I have 4 different versions on my development PC........
Best regards,
Mike Glover
Mike Glover
Users browsing this forum: No registered users and 51 guests
