madramper
TwEECer - 351w - A9L initial tune
Post by madramper » Sat Oct 04, 2008 7:41 pm
I have a 351w in my truck running off of an A9L. The meter is a C&L 76mm with 30# injectors. I have no emissions crap on the truck. These are the changes I plan on making. Is there anything else you would suggest?
Canister Purge Minimum RPM 9999
Canister Purge OL Enable 2
Checksum Base Address 0
EGR System Type 2
Engine Displacement 351
Idle in Gear 800
Idle in Neutral 800
Injector Slope High 30.5
Injector Slope Low 38.5
Thermactor Air Control Logic Enabled 0
Do I need breakpoint and minimum pulsewidth for injectors?
I have the MAF transfer in excel format that I got from VRIstang's website. How do I enter that? I know where it is, but it shows the first four X/Y axis as 0/13.629. Do I keep them as 0?
Thanks for the help!
Black 93 Lightning #4396 - 7-2-93
Stock Bottom End - 75k miles
Custom Ed Curtis AFR 165s
Trick Flow Stage 2 Cam
Pro-E mass air
Circle-D 2800 stall converter
Punished E4OD
My own 1 3/4" longtubes
My own CAI
Power adder: size 13 right foot!
Some other junk
Adam McLaughlin
Re: TwEECer - 351w - A9L initial tune
Post by Adam McLaughlin » Tue Oct 07, 2008 12:50 am
OOOh. We should chat. I too am running a 5.8L motor with an A9L, mustang harness etc.
Adam
1989 GT with V-2 SQ, 42 lb and 80 MM Pro-M MAF. Twisted Wedge H/C/I - A9L
1992 Ranger with 9.4 : 1 357 C.I. Mustang MAF - AFR 185s - A9L - TFS Stage 2
vristang
Post by vristang » Fri Oct 10, 2008 1:28 pm
EDIT: I need to pay more attention when reading.... :oops:
If you don't need all the cells in the MAF Transfer, then yes, leave them blank (or as they are now at 0).
Does the vehicle run now without a tune?
jason
87 LX N/A 2.3 - CZAJL & EDIS
madramper
Post by madramper » Fri Oct 10, 2008 2:14 pm
Yes it runs, but I haven't left the garage with it yet. I have a few things I need to address before I can drive it, but that should be this weekend. I was having a problem with an O2 sensor not reading that I may have a fix for. I am also idling at 18:1 AFR, but I think I figured that one out... maybe. This is my first experience with mass air and I have a major no-no. I have open valve cover breathers and the PCV valve is hooked up. I am hoping that when I pull the vacuum hose from the PCV that it will fix that.
The only thing I have in the tune so far is removing the EGR and raising the idle rpm. I also saved the payload so I could datalog while it is running.
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
Post by cgrey8 » Fri Oct 10, 2008 2:19 pm
If you have a heavy overlap cam or a wide duration, you could get WB readings in the 18s just because of air short-cycling through the engine. Since there is no smog pump, it wouldn't be that.
So what cam are you running? If it's stock, it isn't likely to be a cam issue running you lean at idle. But I thought I'd ask...
madramper
Post by madramper » Fri Oct 10, 2008 2:22 pm
The cam is a trick flow stage 2
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
vristang
Post by vristang » Sat Oct 11, 2008 9:28 pm
madramper wrote: This is my first experience with mass air and I have a major no-no. I have open valve cover breathers and the PCV valve is hooked up. I am hoping that when I pull the vacuum hose from the PCV that it will fix that.
That is basically a vac leak... unmetered air...
You will want to fix that.
Also, check for Diagnostic codes...
Tuning while the ecu is in a alternate strategy will just piss you off.
Just guessing as I don't have any personal experience with that cam, but it shouldn't be causing you any issues.
jason
madramper
Post by madramper » Sun Oct 12, 2008 8:37 am
The vaccum leak is plugged now. The cam is afairly large, but I don't think its big enough to cause a problem. I am still pulling 12" of vacuum after plugging the PCV. I'll get some more testing done and get back to you.
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
madramper
Post by madramper » Thu Oct 16, 2008 10:12 am
I entered the MAF transfer and saved the file. I know CalEdit changes the numbers a little bit, but when I opened the file again, they were no where near what I had set them to. Some of the changes weren't even linear. Like .599v came before .500. What am I doing wrong? Would it be possible for someone to save the MAF transfer and email it to me so I can load it? I am using a C&L 76mm with the purple tube - 30# injectors.
I was going to buy Binary Editor, but I'm not even sure if I am going to stick with the TwEECer. I have been thinking of just having someone tune it for me that knows what they are doing.
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
vristang
Post by vristang » Thu Oct 16, 2008 1:51 pm
CalEdit can be funny with some stuff like that...
Make sure you hit 'Enter' after filling in the value in each cell.
When I used CalEdit I would enter the values, then move over to another tab (Scalars will work), I would click on one of the cells there but not change anything, then go back to the Functions tab to verify that the values I just entered are still correct.
Let us know how that works... This shouldn't be so discouraging that your ready to give up... not yet anyway :evil:
jason
madramper
Post by madramper » Thu Oct 16, 2008 1:58 pm
No, not really discouraged. I have tuned with the tweecer years ago on speed density. I just have not messed with mass air and I really don't have time to learn. I haven't really decided one way or the other. At this point, I don't really have the money to get it tuned yet, so I guess I will stick with it at least for a little while. I need to buy a set of drag radials and get this thing ready for SSOTN on Nov. 15th. I'm hoping it will run good. It should with all of the money I dumped into it this year!!!!
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
Adam McLaughlin
Post by Adam McLaughlin » Fri Oct 17, 2008 9:06 pm
What is it that you exactly want to do with this thing? What would you like to do with this truck?
Adam
madramper
Post by madramper » Fri Oct 17, 2008 9:12 pm
It is 95% street. I only go to the track a couple of times a year. I want it to run low 13's in the 1/4 when I do go to the track. Other than that, I just want it to run good.
I spoke to a local tuner today and he is willing to tune my truck with the tweecer. He has a pretty good reputation and was a top Pro 5.0 racer some years back. So I'll let him tune it and that will give me time to learn the tweecer on my own.
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
cougarnut281
Post by cougarnut281 » Sat Oct 18, 2008 6:34 am
madramper wrote:It is 95% street. I only go to the track a couple of times a year. I want it to run low 13's in the 1/4 when I do go to the track. Other than that, I just want it to run good.
Who is this tuner?
Adam McLaughlin
Post by Adam McLaughlin » Sat Oct 18, 2008 10:33 am
Yeah - the whole reason why I got into this tuning stuff of my own was because the local guy was SO bad... Charged me $800 and didn't do anything right. If you want it done right.. then....
Adam
madramper
Post by madramper » Sat Oct 18, 2008 11:16 am
I got into the tweecer because no one would tune the Lightning speed density. So with the my previous trucks, I was on my own. For the new truck, I figured I would just keep doing it with the mass air, but it is very different from the stock Lightning computer. I want to race in a couple of weeks and definately don't have time to learn it before then.
The tuner's name is Craig Radovich. He owns Radical Racing about a mile from Atco Raceway in NJ. Its about an hour or so from my house.
Pro-E mass air
Punished E4OD
My own CAI
Some other junk
struckby
Post by struckby » Sun Nov 09, 2008 7:58 am
hey Chip!!
....subscribing
#9 1995 Ford Lightning
Best Time 12.4 @107.55 n/a
Goal 12.2@ 110 mph
madramper
Post by madramper » Sun Nov 09, 2008 8:19 am
Craig at Radical Racing took care of me! I was there to navagate through the software and he made the changes needed. Without adding timing, it made 303 rwhp and 380 rwtq. I am heading to the track on Saturday to see what she'll run.
Adam McLaughlin
Post by Adam McLaughlin » Sun Nov 09, 2008 9:48 pm
That's cool, how is the driveability?
Adam
Users browsing this forum: No registered users and 115 guests
