Looking for BE2010.ZIP Build 40
Hey everyone. I'm reaching out to the forum members here looking for the last release of BE2010 (build 40). I recently transferred my BE2010 to a new PC with the help of Clint. Unfortunately I realized after the transfer that my BE2010 install that I had kept was only of build 6 and I need at least build 38. I asked Clint for the last build but he said that he no longer has BE2010. He said that he would look for a backup of it. So, I thought perhaps I could reach out to someone here who may have a copy on hand and save Clint the trouble of digging through his backups for it. recklessford at gmail.com
BE EA QH1.4 GUFB
Re: Looking for BE2010.ZIP Build 40
40 sucks, you don't want anything past 32
If you are using BE 2010 then you should be using build 41.
Would you happen to have a copy?sailorbob wrote:If you are using BE 2010 then you should be using build 41.
BE EA QH1.4 GUFB
Email sent.
Both of you have sent me the .exe and they both work in terms of BE starts up as the appropriate build number. But, whenever i plug in my QH I get the error in the attached pic.
I only get it when using the .exe's that were sent me. However, it works fine with the build 6 .exe
I have done an uninstall reinstall of both BE and the FTD drivers (ftd clean) I also got the latest version of the ftd drivers. no change.
Again, BE recognises the QH just fine when used with the executable that it was installed with. Any suggestions?
BE EA QH1.4 GUFB
can i get the link to be2010 as well i currently have update 40. derek when i bought a def from you last year the installer linked in my email was corrupted or bad, it would not run in win 7 or xp just come up then close in a few seconds. has this been fixed since then?
62 falcon 4.6dohc czajl z4h0
85capri 2013 302, boss intake ms3
60 f100 427w e4od ahacb
83capri ms3 384w s475 e85 mid 9's
02 f350 7.3
02 f350 7.3
