already got the water pump covered
decipha wrote:supports variable speed fan, dual speed fan, electric water pump
.... 3g is wireless broadband internet from verizon, etc... not wifi (802.11x). midwest east is almost completely covered, only weak areas are to the west in less populated zones.decipha wrote:3g wont cut it, not too many folks steal a car then take said vehicle to the nearest starbucks and hang out, so that really wouldnt be reliable
check out the link in my sig for updatesdecipha wrote:ability to run multiple injectors per cylinder and/or manifold injection (tbi)
supports sequential direct port injection and throttle body injection in sync
flow matched injectors are not required
well, there ya go lol. GM TBI control. MAP based. 2 injector throttle body. uses GM 8 pin dist. some info on the dist, in relation to the Megasquirt for reference:decipha wrote:check out the link in my sig for updatesdecipha wrote:ability to run multiple injectors per cylinder and/or manifold injection (tbi)
Just researching some speed parameter info and came across this, quite old but I was thinkingdecipha wrote:no "if" about it, even 'if' i stop now i have enough of it done to do everything+ what the factory ford computer could do up to 2004, so either way its not a complete failure
