Lars
Happy with my TwEECer.
Post by Lars » Thu Apr 15, 2004 10:54 am
Wow, this thing is great, I only have tweeked my car three or four times, and my car is pulling harder on the top end, and I fixed my surging idle with it yesterday. :)
91 LX hatch, A9L, BE/EA, 347, TFS heads, TFS "R" intake, 75mm Accufab TB, 30lb injectors, Pro-M 76mm MAF, Comp cam (219 int, 230 exh, .571 int, .569 exh), Hooker shorties, TKO-600.
Brian-Mc
Re: Happy with my TwEECer.
Post by Brian-Mc » Thu Apr 15, 2004 11:07 am
Lars wrote:Wow, this thing is great, I only have tweeked my car three or four times, and my car is pulling harder on the top end, and I fixed my surging idle with it yesterday. :)
Do you care to give more details what you did to improve your surge at idle?
306 (stock block),TFS Track Heat Heads, E303 Cam, TFS track heat intake, 70 mm TB, 75mm Pro-M,42 lb injectors,Aeromotive AFPR, 255 lph intank, Crane Hi-6/LX-92. Turbonetics 60-1 hi-fi
A9L using Binary Editor
Lars
Post by Lars » Thu Apr 15, 2004 2:21 pm
Yeah, I bumped my idle_in_gear and idle_in_neutral scalars from 672 to 944 on both and it idles great. It was hunting from 500 to 1500 after I installed my electric fan (guess 30+ amps put a bit of a load on the alt.). I have a little bit of a hang in the idle when rolling up to stop lights etc. but at least it's not trying to die now.
Brian-Mc
Post by Brian-Mc » Thu Apr 15, 2004 2:41 pm
So now your car is idling around 1000 rpm on your tach?
Lars
Post by Lars » Thu Apr 15, 2004 5:21 pm
Yup...
pthornton
Post by pthornton » Thu Apr 15, 2004 9:59 pm
http://www.nilesedge.org/wiki/index.php ... alibration
Follow the instructions on this site and you can get that idle back down. My car idles at 780 and never hunts. Just upping the idle is hiding the real problem.
Cobra Intake / AFR 165 Heads
CompCams 270H Camshaft
1989 Saleen Coupe # 653 *****
Lars
Post by Lars » Thu Apr 15, 2004 10:45 pm
pthornton wrote:http://www.nilesedge.org/wiki/index.php ... alibration
Thanks Pt, I'm gonna give that a shot, I really wanted the idle lower so I could hear my cam a bit. I set it up the way it is now so it would quite dying. :?
Ghudnub
Post by Ghudnub » Tue Apr 20, 2004 6:41 pm
You should be able to get it down, I've got a TF Stage 2 at 950 rpm, and I think I can get it down to 875 or so...
'95 GTS lives on in '00 V6 body! 347, J4J1, LPT, 6037's w/Comp Beehives, Extrude honed Cobra, 75mm TB, 87mm Pro-M, TFS Stage 2, 1.7's, 30#r's, LT's, Offroad X-pipe, Bassani catback, and every suspension tweak except for a torque arm.
