Re: SAD disassembler progress
Post by jsa » Sun Feb 02, 2020 4:31 am
DIR
WORD 8C62 8C6D
LST 4.04
8c61: ff,fa               word   faff
8c63: 02,fc               word   fc02
8c65: 01,7d               word   7d01
8c67: 01,80               word   8001
8c69: f0,55               word   55f0
8c6b: a0,40               word   40a0
8c6d: 78                  byte     78
LST 3.08
8c61: ff                  ???
8c62: fa,02               word    2fa
8c64: fc,01               word    1fc
8c66: 7d,01               word    17d
8c68: 80,f0               word   f080
8c6a: 55,a0               word   a055
8c6c: 40,78               word   7840
Post by jsa » Sun Feb 02, 2020 4:46 am
DIR
rbase f6 cf34
4.04 LST 4b
b1ec: 9b,f6,4b,be         cmpb  Rbe,[Rf6+4b]
b1f0: d9,0b               jgtu  b1fd             if (ATMR1 > 4b) goto b1fd;
3.08 LST cf7f
b1f0: d9,0b               jgtu  b1fd             if (ATMR1 > [cf7f]) goto b1fd;
Post by jsa » Sun Feb 02, 2020 5:02 am
DIR
timer BA73 BBA6 : W N
4.04 LST null
b999: a1,73,ba,30         ldw   R30,ba73         R30 = @(null);
3.08
b999: a1,73,ba,30         ldw   R30,ba73         R30 = ba73;
Post by jsa » Fri Feb 07, 2020 5:09 am
I ran 4.04 on DADS.bin which is an old 32kb bin for the Mk5/6 Escort RS2000.
From a cold start it has disassembled the filler and strategy description at the end of the bin as a Table.
Post by tvrfan » Fri Feb 07, 2020 2:25 pm
Thanks John,
At the moment, I am looking at ways to
1. Expand the ends of the 1D functions correctly. Easy if end rows are not all zero.
2. Find a better way to get rows x cols for 2D tables. Trying out a 'least differences' approach which seems to have promise.
Have noted that SAD sometimes gets the tables sizes wrong. (4.0.x actually WORSE than 3.x here. Getting variable arguments to work has affected a lot of other things). This will lead to -
3. Try to sort out remaining data structs like the injection table automatically too.
Some good bugs there to look at. Thanks. I take it they are on CARD ??
NB. There can often be 'phantom' addresses, because a LDW, 2644; could be the address of a data structure, or a mask value, or a multiplier, etc.
Compared to LDX, [R0+2345] ; which is easy, it's always an address. So there are often implied WORD 2644 2645 commands which are deleted internally later, but not always. This is why incorrect WORD, BYTE items sometimes pop up. A TABLE as you described would mean it's picked up a faulty address from somewhere..... This is one of a few 'uncertain' bits in a disassembly, which I think will always be a 'best guess'
I'll copy your posted bin and have a look.
The csv looks doable. I'll get a full BE def and have a look. Of course the descriptions etc are in my comments file, but still OK.
Have spotted a listing bug in indexed opcode printouts in 4.0.4. This sometimes drops the register off the [Rx + 2222] type instructions, and can also mess up any symbols associated. Fixed this in next version.
Post by jsa » Fri Feb 07, 2020 5:43 pm
Yes CARD bugs prior to the DADS post.
Yes, I hear you on LDW.
GUFB DEF available from BE site.
http://www.eecanalyzer.net/strategies?v ... fileId=553
Yes comments that are output to listing are in CMT file.
This is fairly typical of comments I place in DIR. These are not intended to go to LST, but provide a breif description of the SYM. Having a breif description in CMT intended for LST gets very messy where the SYM address is used multiple times.
SYM BC06 "S.DC7_PRD_DT"             #W # Period in DUCE Ticks Ch7
Post by tvrfan » Sat Feb 08, 2020 3:23 am
jsa,
I see that the DADS bin eludes SAD completely for data items.
I've seen this in a few places in xdt2, where several funcs are referred to via a small list with a register as an index, but DADS seems to do EVERYTHING from preset registers which are NOT setup via the 'standard' rbase mechanism.
OUCH !! That stings.....
This will take some investigation..................................later, after I finish the current batch of stuff.
Post by jsa » Sat Feb 08, 2020 4:43 am
Yeah, a bit messier than my first glance.
No worries, all in good time.
Post by motorhead1991 » Thu Feb 13, 2020 2:43 am
Pym's SAD806x source is posted on OpenEEC if you want to poke through it. He's got some handy utilities built in to that tool.
Post by tvrfan » Thu Feb 13, 2020 7:41 pm
motorhead1991 wrote: ↑Thu Feb 13, 2020 2:43 am Pym's SAD806x source is posted on OpenEEC if you want to poke through it. He's got some handy utilities built in to that tool.
thanks - But now my inner dinosaur comes out... How do I compile c# on linux ?? Ummmm....... :oops: <short delay whilst frantic typing noises happen>...Damn, this stuff is all SO different from doing back end command line scripts.....
Ah... 'Mono' ..right. MonoDevelop for an IDE... OK, I'll have a look (and learn some C#). Don't want to rip off other authors work though.
As stated earlier, I've been looking at data analysis for table sizing and other things where SAD missed them, and there will ALWAYS be missed bits because of how disassembly works IMHO (like a pointer list to multiple data structures) and I don't think there's an easy way to sort that out automatically.
OTOH, I have wondered for a while if I an interactive option, notepad-ish style on the listing, would allow the user to define missing stuff in an easy manner (like select a number block, right click and select "this is a 2D table"), and rename my program to SADIE (Semi Automatic Disassembler with Interactive Extensions). 8)
The human brain is MASSIVELY better at instant pattern recognition, so a 'select and click' type interface actually DOES make sense........
and I have got FLTK stuff working and getting used to it (FLTK is an OS independent graphics lib)....................hmm..........
Post by motorhead1991 » Thu Feb 13, 2020 11:34 pm
tvrfan wrote: ↑Thu Feb 13, 2020 7:41 pm
The beauty of GIT is that you can give him credit while utilizing the code. Eventually, I'd like to get you all talking more readily so an exchange of ideas goes faster 😁
SAD bugs in 4.0.4
Post by tvrfan » Sat Feb 15, 2020 4:30 pm
Just a note for users of SAD -
Am working on data cleanups and table/function sizes/layouts/ends, which don't always work correctly.
I've found a couple of bugs to fix....may find some more..........
1) indexed instruction prints sometimes drop the register part of the index in the pseudo code, and also this screws up symbol names too.
The assembler print part is correct however.
2) Discovered some tables are MISSED ALTOGETHER. Not sure if this is all bins, but XDT2 and BWAK3N2 show this problem.
will fix in 4.0.5.
Post by tvrfan » Wed Feb 19, 2020 9:31 pm
finally managed to get Mono installed on linux (in a VM) and SAD806x actually compiles and runs, which is great.
I don't know what works on Windows, but on Linux it opens the bin, but not much else.
do I need to change something , or is it pretty much a template at the moment ??
Post by motorhead1991 » Thu Feb 20, 2020 1:35 am
The tool is fully functional on Windows, haven't tried it on Linux yet.
Post by tvrfan » Thu Feb 20, 2020 5:39 pm
motorhead1991 wrote: ↑Thu Feb 20, 2020 1:35 am The tool is fully functional on Windows, haven't tried it on Linux yet.
Ah, of course I forgot, one must always use a bin which conforms to 'the rules', like the venerable A9L.
My humble AA.bin (and others) don't work of course, because it's European, or more likely because it doesn't begin with 0xff 0xfa 0x20......
OK, trying A9L instead seems to have more life.
(sarcastic ? what me ?? )
I'll have a play around with A9L.
Post by jsa » Thu Feb 20, 2020 10:36 pm
Pym is european, that is his primary use.
Post by jsa » Tue Apr 12, 2022 7:29 am
SAD has been updated for word size tables.
The forked build can be found here;
https://github.com/jsa2340/EEC-IV-disas ... evelopment
Hopefully @tvrfan accepts the pull request.
DIR example
SUB 92E33 "SLU92E33_Y16SWTb"   $F swtlu 3C 38
SUB 92E38 "SLU92E38_Y16UWTb"   $F uwtlu 3C 38
SUB 92E45 "SLU92E45_WSWTb"     $F swtlu 3C 38
SUB 92E4A "SLU92E4A_WUWTb"     $F uwtlu 3C 38
Post by tvrfan » Tue Apr 12, 2022 2:24 pm
To all -
I have been insanely busy in past few months, which is why I haven't anything on SAD. I have moved house (sale and purchase was stunningly fast in a 'super hot' housing market... < 2 weeks !!). Busy doing renovations and all sorts of DIY stuff, and too tired at end of each day. As always, more work to do than you think.......
Done a lot of it now, and so will go back to SAD soon.
Main jobs are -
1) add a math function to allow for more complex conversions from lookups. Currently there's only a simple divide (multiply) option.
2) try to redo the function and table recognizer code to cover some of the clever ways Ford referenced multiple tables/functions. Later bins seem to have lookup lists, which I didn't spot. (I switched this code off in last couple of versions as it was producing false matches).
Word tables ?? I've not seen any - which bin ?? Would be interested to see this. The code now should be good enough to accept a different size with new command as jsa push. I haven't reviewed those requests in far too long.......
Word tables - this will require that there must be a 'word lookup' function somewhere, or it's a mod of the long standing table lookup to include size, which means SAD probably won't see automatically.....
Post by jsa » Tue Apr 12, 2022 4:18 pm
Tvrfan,
Didn't you see the email I sent on the 8/4?
I'll resend it now.
Yes the current code seems to be written well enough to cater for a bit of monkey see monkey do editing for word tables.
Post by jsa » Tue Apr 12, 2022 5:22 pm
DOAV6
82c8c: a2,3d,34           ldw   R34,[R3c++]      R34 = [Tb_Addr];
82c8f: a2,3c,36           ldw   R36,[R3c]        R36 = [Tb_Addr];
82c92: 28,25              scall 82cb9            SLU82CB9_wTb.Interpolate ();
0efa8: a1,20,88,3c        ldw   R3c,8820         R3c = Table_18820;
0efac: 10,08              rombk 8
0efae: ef,c4,3c           call  82c75            SLU82C75_WUWTb ();
0efb1: a0,3e,3c           ldw   R3c,R3e          R3c = R3e;
   Table_18820:
18820: e8,0a,e8,0a,e8,0a,e8,0a,e8,0a,e8,0a,e8,0a  table   2792,  2792,  2792,  2792,  2792,  2792,  2792
1882e: e8,0a,e8,0a,e8,0a,e8,0a,e8,0a,e8,0a,e8,0a  table   2792,  2792,  2792,  2792,  2792,  2792,  2792
92888: 45,4c,07,fe,3c     ad3w  R3c,Rfe,74c      R3c = Table_18576;
9288d: 10,08              rombk 8
9288f: ef,e3,03           call  82c75            SLU82C75_WUWTb ();
92892: c0,28,3e           stw   R3e,R28          R28 = R3e;
   Table_18576:
18576: 75,01,68,01,55,01,47,01,85,01,f3,01  table    373,   360,   341,   327,   389,   499
18582: fc,06,41,07,73,07,a7,07,e8,07,53,08  table   1788,  1857,  1907,  1959,  2024,  2131
1858e: 82,0c,1a,0d,92,0d,07,0e,4a,0e,b3,0e  table   3202,  3354,  3474,  3591,  3658,  3763
1859a: 08,12,f4,12,b0,13,67,14,ad,14,13,15  table   4616,  4852,  5040,  5223,  5293,  5395
185a6: 8f,17,cd,18,cf,19,c7,1a,10,1b,73,1b  table   6031,  6349,  6607,  6855,  6928,  7027
185b2: 15,1d,a7,1e,ee,1f,27,21,73,21,d3,21  table   7445,  7847,  8174,  8487,  8563,  8659
928df: 45,94,07,fe,3c     ad3w  R3c,Rfe,794      R3c = Table_185be;
928e4: 10,08              rombk 8
928e6: ef,8c,03           call  82c75            SLU82C75_WUWTb ();
928e9: a0,3e,2c           ldw   R2c,R3e          R2c = R3e;
   Table_185be:
185be: ea,02,26,03,64,03,d7,03,8d,04,83,05  table    746,   806,   868,   983,  1165,  1411
185ca: 96,02,ce,02,07,03,81,03,5f,04,98,05  table    662,   718,   775,   897,  1119,  1432
185d6: 41,02,76,02,aa,02,2b,03,30,04,ac,05  table    577,   630,   682,   811,  1072,  1452
185e2: ed,01,1d,02,4e,02,d5,02,02,04,c0,05  table    493,   541,   590,   725,  1026,  1472
185ee: 98,01,c5,01,f1,01,7f,02,d4,03,d5,05  table    408,   453,   497,   639,   980,  1493
185fa: 44,01,6d,01,94,01,29,02,a5,03,e9,05  table    324,   365,   404,   553,   933,  1513
Post by jsa » Tue Apr 12, 2022 5:38 pm
FM20M06
87e3d: a2,3d,3e           ldw   R3e,[R3c++]      R3e = [R3c++];
87e40: a2,3c,36           ldw   R36,[R3c]        R36 = [R3c];
87e43: 28,26              scall 87e6b            SLU87E6B_wTb.Interpolate ();
838cf: 45,5e,0a,f0,3c     ad3w  R3c,Rf0,a5e      R3c = Table_12a5e;
838d4: ef,50,45           call  87e27            SLU87E27_WSWTb ();
838dd: c3,dc,ec,3e        stw   R3e,[Rdc+ec]     R16c = R3e;
   Table_12a5e:
12a5e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
12a7e: 40,06,60,01,f0,00,a0,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    352,    240,    160,     80,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
12a9e: 40,06,a0,02,00,02,50,01,e0,00,b0,00,90,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    672,    512,    336,    224,    176,    144,     80,      0,
        0,      0,      0,      0,      0,      0,      0
12abe: 40,06,c0,03,c0,03,c0,02,c0,01,60,01,30,01,00,01,e0,00,70,00,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    704,    448,    352,    304,    256,    224,
        112,      0,      0,      0,      0,      0,      0
12ade: 40,06,c0,03,c0,03,80,03,b0,02,20,02,f0,01,d0,01,90,01,f0,00,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    896,    688,    544,    496,    464,    400,
        240,      0,      0,      0,      0,      0,      0
12afe: 40,06,c0,03,c0,03,c0,03,c0,03,50,03,00,03,a0,02,10,02,40,01,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    960,    960,    848,    768,    672,    528,
        320,      0,      0,      0,      0,      0,      0
12b1e: 40,06,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,50,03,50,02,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    960,    960,    960,    960,    960,    848,
        592,      0,      0,      0,      0,      0,      0
12b3e: 40,06,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,a0,03,e0,02,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    960,    960,    960,    960,    960,    928,
        736,      0,      0,      0,      0,      0,      0
12b5e: 40,06,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,40,03,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    960,    960,    960,    960,    960,    960,
        832,      0,      0,      0,      0,      0,      0
12b7e: 40,06,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,c0,03,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,    960,    960,    960,    960,    960,    960,    960,    960,
        960,      0,      0,      0,      0,      0,      0
12b9e: 40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,
        1600,      0,      0,      0,      0,      0,      0
12bbe: 40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,
12bde: 40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,
12bfe: 40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,
12c1e: 40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,40,06,00,00,00,00,00,00,00,00,00,00,00,00  table    1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,   1600,
12c3e: 64,2b,25,1f,1e,1e,1e,1e,1e,1e,1e,64,2e,2d,2c,29,24,20,20,20,20,1e,64,37,34,30,2e,2c,2c,2a,26,21  table   11108,   7973,   7710,   7710,   7710,  25630,  11566,  10540,   8228,
        8224,   7712,  14180,  12340,  11310,  10796,   8486
12c5e: 1e,64,3c,3c,37,36,35,33,31,2c,2a,26,64,3c,3c,3c,3a,39,38,37,32,30,2c,64,3c,3c,3c,3c,3c,3c,3c,37  table   25630,  15420,  13879,  13109,  11313,   9770,  15460,  15420,  14650,
        14136,  12338,  25644,  15420,  15420,  15420,  14140
12c7e: 34,30,64,40,40,40,40,40,40,40,3b,37,34,64,40,40,40,40,40,40,40,40,3c,3a,64,40,40,40,40,40,40,40  table   12340,  16484,  16448,  16448,  16448,  14139,  25652,  16448,  16448,
        16448,  16448,  14908,  16484,  16448,  16448,  16448
12c9e: 40,40,3c,64,43,43,43,43,43,43,43,43,45,40,32,30,28,20,1e,1e,1e,1e,1e,1e,1e,3c,30,30,2e,2a,24,20  table   16448,  25660,  17219,  17219,  17219,  17219,  16453,  12338,   8232,
        7710,   7710,   7710,  15390,  12336,  10798,   8228
12cbe: 20,20,20,1e,64,37,37,32,2e,2c,2c,2a,26,21,1e,64,3c,3c,37,36,35,33,31,2c,2a,26,64,3c,3c,3c,39,39  table    8224,   7712,  14180,  12855,  11310,  10796,   8486,  25630,  15420,
        13879,  13109,  11313,   9770,  15460,  15420,  14649
12cde: 39,37,32,30,2c,64,3c,3c,3c,3c,3c,3c,3c,37,34,30,64,41,41,41,41,41,41,41,3c,37,34,64,41,41,41,41  table   14137,  12338,  25644,  15420,  15420,  15420,  14140,  12340,  16740,
        16705,  16705,  16705,  14140,  25652,  16705,  16705
12cfe: 41,41,41,41,3c,3a,64,41,41,41,41,41,41,41,41,41,3c,64,46,46,46,46,46,46,46,46,46,41,c0,ff,c0,00  table   16705,  16705,  14908,  16740,  16705,  16705,  16705,  16705,  25660,
        17990,  17990,  17990,  17990,  16710,    -64,    192
83c0b: 45,7e,07,f0,3c     ad3w  R3c,Rf0,77e      R3c = Table_1277e;
83c10: ef,17,42           call  87e2a            SLU87E2A_WUWTb ();
83c13: c3,de,60,3e        stw   R3e,[Rde+60]     R2e0 = R3e;
   Table_1277e:
1277e: 66,1e,33,1b,00,18,33,13,00,10,00,10,00,10,cd,10,1f,15,7b,18,cd,1c,cd,28,00,30,3d,32,b8,42,fc,ff  table   7782,  6963,  6144,  4915,  4096,  4096,  4096,  4301,  5407,  6267,  7373
        , 10445, 12288, 12861, 17080, 65532
1279e: 33,1b,cd,14,0a,13,3d,12,00,10,00,10,00,10,cd,10,1f,15,7b,18,cd,1c,cd,28,00,30,3d,32,b8,42,fc,ff  table   6963,  5325,  4874,  4669,  4096,  4096,  4096,  4301,  5407,  6267,  7373
127be: b8,16,33,13,8f,12,f6,10,00,10,00,10,00,10,cd,10,1f,15,7b,18,cd,1c,cd,28,00,30,3d,32,b8,42,fc,ff  table   5816,  4915,  4751,  4342,  4096,  4096,  4096,  4301,  5407,  6267,  7373
127de: 71,15,b8,12,c3,11,00,10,00,10,00,10,00,10,cd,10,1f,15,7b,18,cd,1c,cd,28,00,30,3d,32,b8,42,fc,ff  table   5489,  4792,  4547,  4096,  4096,  4096,  4096,  4301,  5407,  6267,  7373
127fe: 7b,14,8f,12,71,11,00,10,00,10,00,10,00,10,cd,10,1f,15,7b,18,cd,1c,cd,28,00,30,3d,32,b8,42,fc,ff  table   5243,  4751,  4465,  4096,  4096,  4096,  4096,  4301,  5407,  6267,  7373
1281e: 29,14,8f,12,48,11,00,10,00,10,00,10,00,10,cd,10,48,15,1f,19,cd,1c,1f,29,00,30,3d,32,b8,42,fc,ff  table   5161,  4751,  4424,  4096,  4096,  4096,  4096,  4301,  5448,  6431,  7373
        , 10527, 12288, 12861, 17080, 65532
1283e: 85,13,66,12,f6,10,00,10,00,10,00,10,00,10,cd,10,71,15,9a,19,66,1e,71,29,00,30,3d,32,b8,42,fc,ff  table   4997,  4710,  4342,  4096,  4096,  4096,  4096,  4301,  5489,  6554,  7782
        , 10609, 12288, 12861, 17080, 65532
1285e: 48,11,cd,10,00,10,00,10,00,10,00,10,00,10,1f,11,c3,15,9a,19,66,1e,ec,29,00,30,3d,32,b8,42,fc,ff  table   4424,  4301,  4096,  4096,  4096,  4096,  4096,  4383,  5571,  6554,  7782
        , 10732, 12288, 12861, 17080, 65532
1287e: 00,10,00,10,00,10,00,10,00,10,00,10,00,10,48,11,14,16,9a,19,66,1e,66,2a,00,30,3d,32,b8,42,fc,ff  table   4096,  4096,  4096,  4096,  4096,  4096,  4096,  4424,  5652,  6554,  7782
        , 10854, 12288, 12861, 17080, 65532
1289e: 00,10,00,10,00,10,00,10,00,10,00,10,00,10,71,11,66,16,9a,19,66,1e,e1,2a,00,30,3d,32,b8,42,fc,ff  table   4096,  4096,  4096,  4096,  4096,  4096,  4096,  4465,  5734,  6554,  7782
        , 10977, 12288, 12861, 17080, 65532
128be: 00,10,00,10,00,10,00,10,00,10,00,10,00,10,9a,11,e1,16,9a,19,66,1e,85,2b,00,30,3d,32,b8,42,fc,ff  table   4096,  4096,  4096,  4096,  4096,  4096,  4096,  4506,  5857,  6554,  7782
        , 11141, 12288, 12861, 17080, 65532
83c42: 45,de,08,f0,3c     ad3w  R3c,Rf0,8de      R3c = Table_128de;
83c47: ef,dd,41           call  87e27            SLU87E27_WSWTb ();
83c4a: c3,de,62,3e        stw   R3e,[Rde+62]     R2e2 = R3e;
   Table_128de:
128de: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
128fe: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
1291e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
1293e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
1295e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
1297e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
1299e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
129be: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
129de: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
129fe: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
12a1e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
12a3e: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,
        0,      0,      0,      0,      0,      0,      0
83c7d: 45,2c,06,f0,3c     ad3w  R3c,Rf0,62c      R3c = Table_1262c;
83c82: ef,a5,41           call  87e2a            SLU87E2A_WUWTb ();
83c89: 6c,3e,24           ml2w  R24,R3e          lR24 *= R3e;
   Table_1262c:
1262c: 50,00,96,00,c8,00,f0,00,9a,01,26,02,ee,02,ee,02,ee,02,ee,02,ee,02,ee,02,ee,02  table     80,   150,   200,   240,   410,   550,   750,   750,   750,   750,   750,   750,   750
12646: 50,00,8c,00,af,00,c8,00,3b,01,a4,01,ee,02,ee,02,ee,02,ee,02,ee,02,ee,02,ee,02  table     80,   140,   175,   200,   315,   420,   750,   750,   750,   750,   750,   750,   750
12660: 50,00,82,00,aa,00,b4,00,09,01,4e,01,0f,02,6e,02,d0,02,ee,02,ee,02,ee,02,ee,02  table     80,   130,   170,   180,   265,   334,   527,   622,   720,   750,   750,   750,   750
1267a: 50,00,67,00,96,00,a5,00,d3,00,09,01,87,01,c9,01,0d,02,3a,02,4e,02,4e,02,4e,02  table     80,   103,   150,   165,   211,   265,   391,   457,   525,   570,   590,   590,   590
12694: 50,00,5f,00,7d,00,94,00,bf,00,e8,00,52,01,8c,01,c8,01,ea,01,08,02,08,02,08,02  table     80,    95,   125,   148,   191,   232,   338,   396,   456,   490,   520,   520,   520
126ae: 50,00,5f,00,7b,00,90,00,b5,00,d7,00,36,01,6a,01,a4,01,cc,01,f4,01,f4,01,f4,01  table     80,    95,   123,   144,   181,   215,   310,   362,   420,   460,   500,   500,   500
126c8: 50,00,5a,00,6e,00,7c,00,a0,00,c7,00,18,01,47,01,80,01,ac,01,f4,01,f4,01,f4,01  table     80,    90,   110,   124,   160,   199,   280,   327,   384,   428,   500,   500,   500
126e2: 50,00,5a,00,6d,00,78,00,96,00,be,00,07,01,2f,01,68,01,aa,01,f4,01,f4,01,f4,01  table     80,    90,   109,   120,   150,   190,   263,   303,   360,   426,   500,   500,   500
126fc: 50,00,5a,00,6c,00,78,00,96,00,b8,00,f9,00,1d,01,51,01,8a,01,f4,01,f4,01,f4,01  table     80,    90,   108,   120,   150,   184,   249,   285,   337,   394,   500,   500,   500
12716: 50,00,5a,00,6c,00,78,00,96,00,b4,00,f8,00,1b,01,50,01,86,01,f4,01,f4,01,f4,01  table     80,    90,   108,   120,   150,   180,   248,   283,   336,   390,   500,   500,   500
12730: 50,00,5a,00,6c,00,78,00,96,00,b2,00,f8,00,1a,01,4f,01,85,01,f4,01,f4,01,f4,01  table     80,    90,   108,   120,   150,   178,   248,   282,   335,   389,   500,   500,   500
1274a: 50,00,5a,00,6c,00,78,00,96,00,b2,00,f8,00,1a,01,4f,01,85,01,f4,01,f4,01,f4,01  table     80,    90,   108,   120,   150,   178,   248,   282,   335,   389,   500,   500,   500
12764: 50,00,5a,00,6c,00,78,00,96,00,b2,00,f8,00,1a,01,4f,01,85,01,f4,01,f4,01,f4,01  table     80,    90,   108,   120,   150,   178,   248,   282,   335,   389,   500,   500,   500
84241: 45,fe,00,fa,3c     ad3w  R3c,Rfa,fe       R3c = Table_13dee;
84246: ef,de,3b           call  87e27            SLU87E27_WSWTb ();
84249: c3,e6,a0,3e        stw   R3e,[Re6+a0]     [10620] = R3e;
   Table_13dee:
13dee: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e04: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e1a: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e30: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e46: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e5c: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
13e72: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
85703: 45,32,04,f4,3c     ad3w  R3c,Rf4,432      R3c = Table_137a6;
85708: ef,1f,27           call  87e2a            SLU87E2A_WUWTb ();
8570b: c3,e0,e6,3e        stw   R3e,[Re0+e6]     R366 = R3e;
   Table_137a6:
137a6: 50,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00  table     80,    80,    80,    80,    80,    80,    80,    80,    80,    80,    80
137bc: 50,00,50,00,50,00,50,00,50,00,50,00,40,00,40,00,28,00,28,00,28,00  table     80,    80,    80,    80,    80,    80,    64,    64,    40,    40,    40
137d2: 50,00,50,00,50,00,50,00,50,00,50,00,28,00,28,00,08,00,08,00,08,00  table     80,    80,    80,    80,    80,    80,    40,    40,     8,     8,     8
137e8: 40,00,40,00,28,00,28,00,28,00,28,00,18,00,18,00,08,00,08,00,08,00  table     64,    64,    40,    40,    40,    40,    24,    24,     8,     8,     8
137fe: 28,00,28,00,18,00,18,00,18,00,18,00,08,00,08,00,08,00,08,00,08,00  table     40,    40,    24,    24,    24,    24,     8,     8,     8,     8,     8
13814: 18,00,18,00,10,00,10,00,10,00,10,00,08,00,08,00,08,00,08,00,08,00  table     24,    24,    16,    16,    16,    16,     8,     8,     8,     8,     8
1382a: 00,ff,00,64,66,3a,33,f3,cd,00,02,50,1a,00,78,00,48,0d,a0,00,18,01  table  65280, 25600, 14950, 62259,   205, 20482,    26,   120,  3400,   160,   280
85781: 45,c2,08,fe,3c     ad3w  R3c,Rfe,8c2      R3c = Table_15502;
85786: ef,a1,26           call  87e2a            SLU87E2A_WUWTb ();
85789: 8b,ff,4a,01,3e     cmpw  R3e,[Rfe+14a]
   Table_15502:
15502: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0,     0,     0,     0,     0
        ,     0,     0,     0,     0,     0
15522: 64,00,16,00,0f,00,0a,00,05,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    22,    15,    10,     5,     0,     0,     0,     0,     0,     0
        ,     0,     0,     0,     0,     0
15542: 64,00,32,00,20,00,15,00,12,00,0e,00,0b,00,08,00,07,00,06,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    50,    32,    21,    18,    14,    11,     8,     7,     6,     0
        ,     0,     0,     0,     0,     0
15562: 64,00,50,00,46,00,3a,00,26,00,17,00,10,00,0f,00,0b,00,07,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    70,    58,    38,    23,    16,    15,    11,     7,     0
        ,     0,     0,     0,     0,     0
15582: 64,00,50,00,50,00,50,00,3c,00,28,00,23,00,1e,00,19,00,14,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    60,    40,    35,    30,    25,    20,     0
        ,     0,     0,     0,     0,     0
155a2: 64,00,50,00,50,00,50,00,50,00,3a,00,34,00,2e,00,21,00,1e,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    80,    58,    52,    46,    33,    30,     0
        ,     0,     0,     0,     0,     0
155c2: 64,00,50,00,50,00,50,00,50,00,50,00,3a,00,38,00,30,00,28,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    80,    80,    58,    56,    48,    40,     0
        ,     0,     0,     0,     0,     0
155e2: 64,00,50,00,50,00,50,00,50,00,50,00,50,00,3e,00,37,00,31,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    80,    80,    80,    62,    55,    49,     0
        ,     0,     0,     0,     0,     0
15602: 64,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,3e,00,38,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    80,    80,    80,    80,    62,    56,     0
        ,     0,     0,     0,     0,     0
15622: 64,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,50,00,41,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,    80,    80,    80,    80,    80,    80,    80,    80,    65,     0
        ,     0,     0,     0,     0,     0
15642: 64,00,64,00,64,00,64,00,50,00,50,00,50,00,50,00,50,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,   100,   100,   100,    80,    80,    80,    80,    80,    80,     0
        ,     0,     0,     0,     0,     0
15662: 64,00,64,00,64,00,64,00,50,00,50,00,50,00,50,00,50,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,   100,   100,   100,    80,    80,    80,    80,    80,    80,     0
        ,     0,     0,     0,     0,     0
15682: 64,00,64,00,64,00,64,00,50,00,50,00,50,00,50,00,50,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,   100,   100,   100,    80,    80,    80,    80,    80,    80,     0
        ,     0,     0,     0,     0,     0
156a2: 64,00,64,00,64,00,64,00,50,00,50,00,50,00,50,00,50,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,   100,   100,   100,    80,    80,    80,    80,    80,    80,     0
        ,     0,     0,     0,     0,     0
156c2: 64,00,64,00,64,00,64,00,50,00,50,00,50,00,50,00,50,00,50,00,00,00,00,00,00,00,00,00,00,00,00,00  table    100,   100,   100,   100,    80,    80,    80,    80,    80,    80,     0
        ,     0,     0,     0,     0,     0
Post by jsa » Tue Apr 12, 2022 6:01 pm
KIEE
82505: a2,3d,34           ldw   R34,[R3c++]      R34 = [Tb_Addr];
82508: a2,3c,36           ldw   R36,[R3c]        R36 = [Tb_Addr];
8250b: 28,25              scall 82532            SLU82532_wTb.Interpolate ();
9c2a9: 45,7c,0b,f6,3c     ad3w  R3c,Rf6,b7c      R3c = Table_1462e;
9c2ae: 10,08              rombk 8
9c2b0: ef,3b,62           call  824ee            SLU824EE_WUWTb ();
9c2b3: c3,01,2c,06,3e     stw   R3e,[R0+62c]     [1062c] = R3e;
   Table_1462e:
1462e: 00,00,00,00,00,00,66,00,66,00,66,00,66,00  table      0,     0,     0,   102,   102,   102,   102
1463c: 8f,00,a4,00,b8,00,cd,00,e1,00,f6,00,0a,01  table    143,   164,   184,   205,   225,   246,   266
1464a: a4,00,cd,00,e1,00,f6,00,0a,01,1f,01,33,01  table    164,   205,   225,   246,   266,   287,   307
14658: cd,00,e1,00,0a,01,1f,01,33,01,48,01,5c,01  table    205,   225,   266,   287,   307,   328,   348
14666: e1,00,1f,01,48,01,5c,01,71,01,85,01,9a,01  table    225,   287,   328,   348,   369,   389,   410
14674: 01,ff,cd,0c,01,a0,01,00,00,00,01,00,01,00  table  65281,  3277, 40961,     1,     0,     1,     1
14682: 00,3c,fa,00,f4,01,30,00,00,00,00,00,0d,22  table  15360,   250,   500,    48,     0,     0,  8717
14690: 00,00,71,76,6e,73,00,80,00,80,01,ff,00,04  table      0, 30321, 29550, 32768, 32768, 65281,  1024
1469e: e8,03,9a,01,81,56,9e,0a,00,00,00,00,be,51  table   1000,   410, 22145,  2718,     0,     0, 20926
Post by jsa » Tue Apr 12, 2022 7:23 pm
KQTH7
19cb1: a2,3d,34           ldw   R34,[R3c++]      R34 = [Tb_Addr];
19cb4: a2,3c,36           ldw   R36,[R3c]        R36 = [Tb_Addr];
19cb7: 28,25              scall 19cde            SLU19CDE_wTb.Interpolate ();
8f1f8: 45,f8,0c,f6,3c     ad3w  R3c,Rf6,cf8      R3c = Table_14e76;
8f1fd: 10,01              rombk 1
8f1ff: ef,98,aa           call  19c9a            SLU19C9A_WUWTb ();
8f202: c3,01,2c,14,3e     stw   R3e,[R0+142c]    [1142c] = R3e;
   Table_14e76:
14e76: 00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0
14e84: 00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0
14e92: 00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0
14ea0: 00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0
14eae: 00,00,00,00,00,00,00,00,00,00,00,00,00,00  table      0,     0,     0,     0,     0,     0,     0
14ebc: 01,01,cd,0c,01,a0,01,00,00,00,01,00,01,00  table    257,  3277, 40961,     1,     0,     1,     1
14eca: 00,3c,fa,00,f4,01,30,00,00,50,81,04,06,14  table  15360,   250,   500,    48, 20480,  1153,  5126
14ed8: 24,22,14,00,00,7f,05,1e,05,0a,0a,00,0f,ec  table   8740,    20, 32512,  7685,  2565,    10, 60431
14ee6: 14,80,14,7f,19,46,19,1e,2d,0a,3c,00,50,80  table  32788, 32532, 17945,  7705,  2605,    60, 32848
14ef4: 64,ff,00,80,00,80,01,ff,00,04,b0,04,9a,01  table  65380, 32768, 32768, 65281,  1024,  1200,   410
96c6b: 45,90,05,fe,3c     ad3w  R3c,Rfe,590      R3c = swTb.1749A;
96c70: 10,01              rombk 1
96c72: ef,20,30           call  19c95            SLU19C95_WSWTb ();
96c75: c3,01,94,04,3e     stw   R3e,[R0+494]     [10494] = R3e;
   swTb.1749A:
1749a: 00,00,00,00,9a,01,00,02,66,02,66,02  table       0,      0,    410,    512,    614,    614
174a6: 00,00,00,00,00,02,cd,02,66,03,cd,02  table       0,      0,    512,    717,    870,    717
174b2: 00,00,00,00,00,02,cd,02,66,03,cd,02  table       0,      0,    512,    717,    870,    717
174be: 00,00,00,00,00,02,cd,02,33,03,cd,02  table       0,      0,    512,    717,    819,    717
174ca: 00,00,00,00,00,02,cd,02,00,03,cd,02  table       0,      0,    512,    717,    768,    717
174d6: 00,00,00,00,00,02,cd,02,00,03,cd,02  table       0,      0,    512,    717,    768,    717
Post by jsa » Tue Apr 12, 2022 7:39 pm
RZASA
92e61: a2,3d,34           ldw   R34,[R3c++]      TMP1L = [Tb_Addr];
92e64: a2,3c,36           ldw   R36,[R3c]        TMP2L = [Tb_Addr];
92e67: 28,25              scall 92e8e            SLU92E8E_wTb.Interpolate ();
09704: a1,9c,5c,3c        ldw   R3c,5c9c         TMP5L = Table_15c9c;
09708: 10,09              rombk 9
0970a: ef,26,97           call  92e33            SLU92E33_Y16SWTb ();
0970d: a0,3e,3c           ldw   R3c,R3e          TMP5L = TMP6L;
   Table_15c9c:
15c9c: 33,02,00,02,66,01,4d,01,33,01,00,f6,00,f6,00,f6  table     563,    512,    358,    333,    307,  -2560,  -2560,  -2560
15cac: 33,02,00,02,66,01,4d,01,33,01,00,f6,00,f6,00,f6  table     563,    512,    358,    333,    307,  -2560,  -2560,  -2560
15cbc: 33,02,00,02,66,01,4d,01,33,01,00,00,00,f6,00,f6  table     563,    512,    358,    333,    307,      0,  -2560,  -2560
15ccc: 33,02,00,02,66,01,4d,01,9a,00,00,00,00,fe,00,f6  table     563,    512,    358,    333,    154,      0,   -512,  -2560
15cdc: 33,02,00,02,66,01,00,01,00,00,00,fe,00,f6,00,f6  table     563,    512,    358,    256,      0,   -512,  -2560,  -2560
15cec: 33,02,00,02,66,01,33,00,00,fe,00,f6,00,f6,00,f6  table     563,    512,    358,     51,   -512,  -2560,  -2560,  -2560
15cfc: 33,02,00,02,66,01,00,00,00,f6,00,f6,00,f6,00,f6  table     563,    512,    358,      0,  -2560,  -2560,  -2560,  -2560
15d0c: 33,02,00,02,66,01,00,fe,00,f6,00,f6,00,f6,00,f6  table     563,    512,    358,   -512,  -2560,  -2560,  -2560,  -2560
0977a: a1,3c,5d,3c        ldw   R3c,5d3c         TMP5L = Table_15d3c;
0977e: 10,09              rombk 9
09780: ef,b0,96           call  92e33            SLU92E33_Y16SWTb ();
09783: a0,3e,3c           ldw   R3c,R3e          TMP5L = TMP6L;
   Table_15d3c:
15d3c: 00,fc,00,02,cd,00,9a,00,00,00,00,00,33,00,00,f6  table   -1024,    512,    205,    154,      0,      0,     51,  -2560
15d4c: 00,fc,00,00,00,00,00,00,00,00,00,00,33,00,00,f6  table   -1024,      0,      0,      0,      0,      0,     51,  -2560
15d5c: 00,fc,00,00,00,00,00,00,00,00,00,00,00,00,00,f6  table   -1024,      0,      0,      0,      0,      0,      0,  -2560
15d6c: 00,fc,00,00,00,00,00,00,00,00,00,00,00,fe,00,f6  table   -1024,      0,      0,      0,      0,      0,   -512,  -2560
15d7c: 00,fc,00,00,00,00,00,00,00,00,00,00,00,fe,00,f6  table   -1024,      0,      0,      0,      0,      0,   -512,  -2560
15d8c: 00,fc,00,00,00,00,00,00,00,00,00,00,00,f6,00,f6  table   -1024,      0,      0,      0,      0,      0,  -2560,  -2560
15d9c: 00,fc,00,00,00,00,00,00,00,00,00,00,00,f6,00,f6  table   -1024,      0,      0,      0,      0,      0,  -2560,  -2560
15dac: 00,fc,00,00,00,fe,00,f6,00,f6,00,f6,00,f6,00,f6  table   -1024,      0,   -512,  -2560,  -2560,  -2560,  -2560,  -2560
86278: 45,cc,06,f4,3c     ad3w  R3c,Rf4,6cc      TMP5L = Table_12db2;
8627d: 10,09              rombk 9
8627f: ef,c3,cb           call  92e45            SLU92E45_WSWTb (); } } } } } }
86282: c3,29,66,11,3e     stw   R3e,[R28+1166]   [TEMP2L+11166] = TMP6L;
   Table_12db2:
12db2: ae,ff,85,ff,85,ff,85,ff,85,ff,85,ff  table     -82,   -123,   -123,   -123,   -123,   -123
12dbe: ae,ff,ae,ff,85,ff,85,ff,85,ff,85,ff  table     -82,    -82,   -123,   -123,   -123,   -123
12dca: 00,00,00,00,85,ff,85,ff,85,ff,85,ff  table       0,      0,   -123,   -123,   -123,   -123
12dd6: 00,00,00,00,d7,ff,d7,ff,d7,ff,d7,ff  table       0,      0,    -41,    -41,    -41,    -41
12de2: 14,00,14,00,00,00,00,00,00,00,00,00  table      20,     20,      0,      0,      0,      0
12dee: 3d,00,52,00,00,00,00,00,00,00,00,00  table      61,     82,      0,      0,      0,      0
12dfa: 52,00,7b,00,52,00,52,00,52,00,52,00  table      82,    123,     82,     82,     82,     82
12e06: 52,00,7b,00,7b,00,7b,00,7b,00,7b,00  table      82,    123,    123,    123,    123,    123
12e12: 52,00,7b,00,7b,00,7b,00,7b,00,7b,00  table      82,    123,    123,    123,    123,    123
12e1e: 52,00,7b,00,7b,00,7b,00,7b,00,7b,00  table      82,    123,    123,    123,    123,    123
864a4: 45,44,07,f4,3c     ad3w  R3c,Rf4,744      TMP5L = Table_12e2a;
864a9: 10,09              rombk 9
864ab: ef,97,c9           call  92e45            SLU92E45_WSWTb ();
864b3: fe,4c,3c,3e,3c     sml3w R3c,R3e,R3c      TMP5L = TMP6L * TMP5L;
   Table_12e2a:
12e2a: b8,fe,b8,fe,b8,fe,b8,fe,b8,fe,b8,fe  table    -328,   -328,   -328,   -328,   -328,   -328
12e36: b8,fe,b8,fe,b8,fe,b8,fe,b8,fe,b8,fe  table    -328,   -328,   -328,   -328,   -328,   -328
12e42: b8,fe,b8,fe,b8,fe,b8,fe,b8,fe,b8,fe  table    -328,   -328,   -328,   -328,   -328,   -328
12e4e: b8,fe,b8,fe,b8,fe,b8,fe,b8,fe,b8,fe  table    -328,   -328,   -328,   -328,   -328,   -328
12e5a: 00,00,00,00,00,00,00,00,00,00,00,00  table       0,      0,      0,      0,      0,      0
12e66: 48,01,48,01,48,01,48,01,48,01,48,01  table     328,    328,    328,    328,    328,    328
12e72: 48,01,48,01,48,01,48,01,48,01,48,01  table     328,    328,    328,    328,    328,    328
12e7e: 48,01,48,01,48,01,48,01,48,01,48,01  table     328,    328,    328,    328,    328,    328
12e8a: 48,01,48,01,48,01,48,01,48,01,48,01  table     328,    328,    328,    328,    328,    328
12e96: 48,01,48,01,48,01,48,01,48,01,48,01  table     328,    328,    328,    328,    328,    328
93348: 45,6e,11,fe,3c     ad3w  R3c,Rfe,116e     TMP5L = Table_1873c;
9334d: ef,fa,fa           call  92e4a            SLU92E4A_WUWTb ();
93350: c0,28,3e           stw   R3e,R28          TEMP2L = TMP6L;
   Table_1873c:
1873c: 73,01,3d,01,7a,01,a3,01,a6,01,86,02  table    371,   317,   378,   419,   422,   646
18748: 2a,08,63,08,dd,08,03,09,50,09,9d,09  table   2090,  2147,  2269,  2307,  2384,  2461
18754: 00,11,90,11,96,12,b7,12,0d,13,00,14  table   4352,  4496,  4758,  4791,  4877,  5120
18760: 00,1a,3d,1b,7d,1c,9a,1c,56,1d,5a,1d  table   6656,  6973,  7293,  7322,  7510,  7514
1876c: e3,22,93,24,43,26,5d,26,6a,27,10,27  table   8931,  9363,  9795,  9821, 10090, 10000
18778: cd,2b,00,2e,13,30,26,30,6d,31,ed,30  table  11213, 11776, 12307, 12326, 12653, 12525
9337e: 45,b6,11,fe,3c     ad3w  R3c,Rfe,11b6     TMP5L = Table_18784;
93383: ef,c4,fa           call  92e4a            SLU92E4A_WUWTb ();
93386: a0,3e,2c           ldw   R2c,R3e          TEMP4L = TMP6L;
   Table_18784:
18784: 40,04,60,04,a0,04,c0,04,60,05,90,08  table   1088,  1120,  1184,  1216,  1376,  2192
18790: 03,04,06,04,73,04,73,04,2d,05,50,08  table   1027,  1030,  1139,  1139,  1325,  2128
1879c: 16,03,23,03,c0,03,d0,03,c0,04,70,08  table    790,   803,   960,   976,  1216,  2160
187a8: b0,02,9d,02,30,03,56,03,5a,04,80,08  table    688,   669,   816,   854,  1114,  2176
187b4: 33,02,56,02,aa,02,fd,02,13,04,c0,08  table    563,   598,   682,   765,  1043,  2240
187c0: e3,01,00,02,4a,02,9a,02,c0,03,2d,09  table    483,   512,   586,   666,   960,  2349
