SAD disassembler progress
Re: SAD disassembler progress
Post by jsa » Sun Feb 02, 2020 4:31 am
DIR
WORD 8C62 8C6D
LST 4.04
8c61: ff,fa               word   faff
8c63: 02,fc               word   fc02
8c65: 01,7d               word   7d01
8c67: 01,80               word   8001
8c69: f0,55               word   55f0
8c6b: a0,40               word   40a0
8c6d: 78                  byte     78
LST 3.08
8c61: ff                  ???
8c62: fa,02               word    2fa
8c64: fc,01               word    1fc
8c66: 7d,01               word    17d
8c68: 80,f0               word   f080
8c6a: 55,a0               word   a055
8c6c: 40,78               word   7840
Post by jsa » Sun Feb 02, 2020 4:46 am
DIR
rbase f6 cf34
4.04 LST 4b
b1ec: 9b,f6,4b,be         cmpb  Rbe,[Rf6+4b]
b1f0: d9,0b               jgtu  b1fd             if (ATMR1 > 4b) goto b1fd;
3.08 LST cf7f
b1f0: d9,0b               jgtu  b1fd             if (ATMR1 > [cf7f]) goto b1fd;
Post by jsa » Sun Feb 02, 2020 5:02 am
DIR
timer BA73 BBA6 : W N
4.04 LST null
b999: a1,73,ba,30         ldw   R30,ba73         R30 = @(null);
3.08
b999: a1,73,ba,30         ldw   R30,ba73         R30 = ba73;
Post by jsa » Fri Feb 07, 2020 5:09 am
I ran 4.04 on DADS.bin which is an old 32kb bin for the Mk5/6 Escort RS2000.
From a cold start it has disassembled the filler and strategy description at the end of the bin as a Table.
DADS.zip
(21.82 KiB) Downloaded 15 times
Post by tvrfan » Fri Feb 07, 2020 2:25 pm
Thanks John,
At the moment, I am looking at ways to
1. Expand the ends of the 1D functions correctly. Easy if end rows are not all zero.
2. Find a better way to get rows x cols for 2D tables. Trying out a 'least differences' approach which seems to have promise.
Have noted that SAD sometimes gets the tables sizes wrong. (4.0.x actually WORSE than 3.x here. Getting variable arguments to work has affected a lot of other things). This will lead to -
3. Try to sort out remaining data structs like the injection table automatically too.
Some good bugs there to look at. Thanks. I take it they are on CARD ??
NB. There can often be 'phantom' addresses, because a LDW, 2644; could be the address of a data structure, or a mask value, or a multiplier, etc.
Compared to LDX, [R0+2345] ; which is easy, it's always an address. So there are often implied WORD 2644 2645 commands which are deleted internally later, but not always. This is why incorrect WORD, BYTE items sometimes pop up. A TABLE as you described would mean it's picked up a faulty address from somewhere..... This is one of a few 'uncertain' bits in a disassembly, which I think will always be a 'best guess'
I'll copy your posted bin and have a look.
The csv looks doable. I'll get a full BE def and have a look. Of course the descriptions etc are in my comments file, but still OK.
Have spotted a listing bug in indexed opcode printouts in 4.0.4. This sometimes drops the register off the [Rx + 2222] type instructions, and can also mess up any symbols associated. Fixed this in next version.
Post by jsa » Fri Feb 07, 2020 5:43 pm
Yes CARD bugs prior to the DADS post.
Yes, I hear you on LDW.
GUFB DEF available from BE site.
http://www.eecanalyzer.net/strategies?v ... fileId=553
Yes comments that are output to listing are in CMT file.
This is fairly typical of comments I place in DIR. These are not intended to go to LST, but provide a breif description of the SYM. Having a breif description in CMT intended for LST gets very messy where the SYM address is used multiple times.
SYM BC06 "S.DC7_PRD_DT"             #W # Period in DUCE Ticks Ch7
Post by tvrfan » Sat Feb 08, 2020 3:23 am
jsa,
I see that the DADS bin eludes SAD completely for data items.
I've seen this in a few places in xdt2, where several funcs are referred to via a small list with a register as an index, but DADS seems to do EVERYTHING from preset registers which are NOT setup via the 'standard' rbase mechanism.
OUCH !! That stings.....
This will take some investigation..................................later, after I finish the current batch of stuff.
Post by jsa » Sat Feb 08, 2020 4:43 am
Yeah, a bit messier than my first glance.
No worries, all in good time.
Post by motorhead1991 » Thu Feb 13, 2020 2:43 am
Pym's SAD806x source is posted on OpenEEC if you want to poke through it. He's got some handy utilities built in to that tool.
Post by tvrfan » Thu Feb 13, 2020 7:41 pm
thanks - But now my inner dinosaur comes out... How do I compile c# on linux ?? Ummmm....... :oops: <short delay whilst frantic typing noises happen>...Damn, this stuff is all SO different from doing back end command line scripts.....
Ah... 'Mono' ..right. MonoDevelop for an IDE... OK, I'll have a look (and learn some C#). Don't want to rip off other authors work though.
As stated earlier, I've been looking at data analysis for table sizing and other things where SAD missed them, and there will ALWAYS be missed bits because of how disassembly works IMHO (like a pointer list to multiple data structures) and I don't think there's an easy way to sort that out automatically.
OTOH, I have wondered for a while if I an interactive option, notepad-ish style on the listing, would allow the user to define missing stuff in an easy manner (like select a number block, right click and select "this is a 2D table"), and rename my program to SADIE (Semi Automatic Disassembler with Interactive Extensions). 8)
The human brain is MASSIVELY better at instant pattern recognition, so a 'select and click' type interface actually DOES make sense........
and I have got FLTK stuff working and getting used to it (FLTK is an OS independent graphics lib)....................hmm..........
Post by motorhead1991 » Thu Feb 13, 2020 11:34 pm
The beauty of GIT is that you can give him credit while utilizing the code. Eventually, I'd like to get you all talking more readily so an exchange of ideas goes faster 😁
SAD bugs in 4.0.4
Post by tvrfan » Sat Feb 15, 2020 4:30 pm
Just a note for users of SAD -
Am working on data cleanups and table/function sizes/layouts/ends, which don't always work correctly.
I've found a couple of bugs to fix....may find some more..........
1) indexed instruction prints sometimes drop the register part of the index in the pseudo code, and also this screws up symbol names too.
The assembler print part is correct however.
2) Discovered some tables are MISSED ALTOGETHER. Not sure if this is all bins, but XDT2 and BWAK3N2 show this problem.
will fix in 4.0.5.
Post by tvrfan » Wed Feb 19, 2020 9:31 pm
finally managed to get Mono installed on linux (in a VM) and SAD806x actually compiles and runs, which is great.
I don't know what works on Windows, but on Linux it opens the bin, but not much else.
do I need to change something , or is it pretty much a template at the moment ??
Post by motorhead1991 » Thu Feb 20, 2020 1:35 am
The tool is fully functional on Windows, haven't tried it on Linux yet.
Post by tvrfan » Thu Feb 20, 2020 5:39 pm
Ah, of course I forgot, one must always use a bin which conforms to 'the rules', like the venerable A9L.
My humble AA.bin (and others) don't work of course, because it's European, or more likely because it doesn't begin with 0xff 0xfa 0x20......
OK, trying A9L instead seems to have more life.
(sarcastic ? what me ?? )
I'll have a play around with A9L.
Post by jsa » Thu Feb 20, 2020 10:36 pm
Pym is european, that is his primary use.
