bobwhite
Lightning C3P2 scalar hex address locations
Post by bobwhite » Mon Dec 08, 2014 12:12 pm
does anyone know the hex addresses of the scalars LAMRICH, LAMRHYS, HLDTIM, HEGO IDLE, TIME OL, XAPT, or CIBETA (and CIBETA multiplier)? I am using STKR 1.30 with a TwEECer RT on a Gen 1 Lightning C3P2 bin and need a few more scalars so I can hex edit them to do what I need to do. Any help would be greatly appreciated.
Re: Lightning C3P2 scalar hex address locations
Post by decipha » Mon Dec 08, 2014 12:40 pm
that's the LHBL0 strategy
you would be much happier if you just got the COMPLETE definition file from sailorbob only $25, it would require you buy BE too which is kinda pricey $200
http://info.efidynotuning.com/derek.htm
bobwhite
Post by bobwhite » Wed Dec 10, 2014 11:36 am
I know. That's $225 that's not in my budget. Need a wideband too. I mainly need LAMRICH and HLDTIM, the others would be nice also. Just need a little info. Decipha , I would be able to try tuning fuel with your "Forced Closed Loop" method using the stock narrowband hego and observing KAMRF, since my truck is norm aspirated and just slightly modified. Thanks
Post by decipha » Wed Dec 10, 2014 11:51 am
you can go about it using other methods you don't have to use those exact scalars
send me over your tune and i'll take a look
decipha at efidynotuning dot com
ender11
Post by ender11 » Tue Dec 16, 2014 12:37 pm
hmm, looks like LHBL0 & LHBH1 are the same?
mpaton
Post by mpaton » Tue Dec 16, 2014 1:17 pm
So can you make your own def file equivalents for CalCon now? That used to be all encrypted.
bobwhite
Post by bobwhite » Mon Dec 22, 2014 11:31 am
Decipha, email with binfile, tune and strat doc sent to you. Thanks
bobwhite
Post by bobwhite » Wed Dec 31, 2014 11:59 am
mpaton, I hexedit PIDs, etc. not included in caledit, in a virgin C3P2.bin, and then install it in caledit and complete the tune. ender11, I think LHBL0 and LHBL1 are similar, but not perfectly identical. the address of some PIDs are probably the same. LAMRICH & others could be in the same address in both. Any info you or anyone else could provide, or could direct me to about LHBL1 & LHBL0 would be very helpful. Thanks
Post by decipha » Thu Jan 01, 2015 6:12 am
cool ill check it out when i get a chance
ender11
Post by ender11 » Tue Jan 06, 2015 7:50 pm
is there something of the bunch c3p2, c3p3, lhbh1 binary decompiled listing?
bobwhite
Post by bobwhite » Sat Jan 10, 2015 4:34 pm
ender11, I have a copy of C3P21st.txt & .dir & .jc & LHBH1 def started by SVOJOHN along with C3P21st.txt & C3P2.msg produced by the S.A.D. disass'y program by TVRFAN. I have found a few scalars by studying the disass'y & LHBH1.pdf strat doc, but I haven't been able to find the scalars mentioned in my original post, yet. Need more knowledge & experience. I'm a gearhead. The partial def started by SVOJOHN doesn't have the scalars I'm interested in. The disass'y fromSVOJOHN & TVRFAN's S.A.D. probably need more breaking down, but that is beyond me at this point in time. Thanks
bobwhite
Post by bobwhite » Tue Jan 20, 2015 12:40 pm
found a couple of useful scalars. AFECT1 is at address $ac50, 83*2=166degF. AFECT2 is at address $ac51, 105*2=210degF. Both scalars are 1 byte. both addresses are for a 56k C3P2 binfile.
ender11
Post by ender11 » Wed Jan 21, 2015 6:40 am
hi bob, check pm, plz!
ender11
Post by ender11 » Sat Jan 24, 2015 4:38 pm
Returning to LHBH1: there is wonderful combination of mpg and power fuel and spark tables, switched on timer VS vechicle speed. and MPG tables are all AFR=1. and there comes some questions: can it handle higher AFR when cruising? solution for everyday street driving? what are safe margins for catalyst equipped vechicle? I considering exhaust gas temp sensor unit.
ender11
Post by ender11 » Sun Jan 25, 2015 1:03 pm
decipha wrote:that's the LHBL0 strategy
sorry for a stupid question, but are those definitions only available for BE users, and can't be viewed apart from BE, say, in old good excel?
Post by jsa » Sun Jan 25, 2015 1:34 pm
That's right BE only.
bobwhite
Post by bobwhite » Sat Feb 14, 2015 10:41 am
thru some good mentoring & help i know LAMRICH is at $9479 and is $73=115/128*14.64=13.15 AFR and LAMRHYS is at $947A and is $03=3/128*14.64=.34 AFR, for a 56K bin. i found PIPOUT at $94A2=4 pips, and TP_HYS_OL at $946C and is $03C0 word=960/12,800=.075 volts. i have been able to safely achieve Forced Closed Loop and should be able to tweec the fuel curve via VE table, using the OEM narrowband HEGO.
Post by decipha » Sat Feb 14, 2015 6:35 pm
excellent
