word address requirements ?
Post by jsa » Fri Oct 23, 2015 2:23 pm
8096 development board document wrote:WORD
A WORD is a 16-bit variable. The address of a WORD is the address of its least significant byte. A WORD must start at an even byte address.
Does it apply to the 8061?
Re: word address requirements ?
Post by decipha » Fri Oct 23, 2015 2:47 pm
theres some missing info
all LOOKUP words SHOULD be on an evenly aligned address boundary i.e. an even address divisible by 4 for the ecu to quickly reference the value, referencing a word as an odd address in the lower 0x400 registers will give you an unexpected result
that doesnt apply to the later eec-v's where the calibration constants/scalars are actually in the code which falls on odd addressing quite frequently
Post by sailorbob » Fri Oct 23, 2015 3:02 pm
Yes, the 8061 and 8065 have the same requirement as the 8096 for word sized data to be stored in memory at an even address.
Post by jsa » Fri Oct 23, 2015 4:28 pm
Thanks gents.
mpaton
Post by mpaton » Fri Oct 23, 2015 6:55 pm
I don't know if there was a different processor for Ford ECUs before EEC-IV, but you will see code in 8061 that loads words a byte at a time. So this word on an address divisible by 2 business may not always have been the case.
Post by jsa » Fri Oct 23, 2015 10:13 pm
8096 section of the 1985 Intel Microcontroller Handbook wrote: 2.9.3. A/D Results
Results of the analog conversions are read from the A/D
Result Register at locations 02H and 03H. Although these
addresses are on a word boundary, they must be read as
individual bytes.
04H & 05H for 8061.
Would, byte at a time read of words be needed once R4&R5 are read and stored as a word somewhere else ?
mpaton wrote:you will see code in 8061 that loads words a byte at a time
A case in point ?
 cc,38             pop   R38            R38 = pop();
 b2,3b,3c          ldb   R3c,[R38++]    R3c = [R38++];
 b2,3b,3d          ldb   R3d,[R38++]    R3d = [R38++];
 c8,38             push  R38            push(R38);
EDIT: Oops fixed, thanks Sailorbob
Post by sailorbob » Sat Oct 24, 2015 3:01 am
The 8061 A/D result register is at address 0x04 and 0x05.
Post by tvrfan » Mon Oct 26, 2015 11:16 pm
A case in point ?
As I said in other thread, the reason for this is as follows.
In code, there is no guarantee that an inline word param will be on an even byte, as opcode length varies, especially for the multiple address modes, so in order to be safe, the code must load a byte at a time. In the example above, it is then safe to use R3c as a word value. (note the POPped value is of course an ADDRESS, and could be odd)
You will see that where there is fixed calibration data, there is quite often a single 0xff filler after one or more byte values, to get an even address for following word value(s).
