joker772005
90 F150 5.0L EEC without a label with catch code
Post by joker772005 » Fri Jul 20, 2012 12:03 am
How wud I go about obtaining my eec catch code on a 90 f150 5.0 auto?
There is not any kind of writing on it that says a ford part # or catch code.I know the eec was replaced under recall or some type of recal back in 95ish.
Mike
1989 cougar 5.0 efi
stock 302 shortblock,afr165 heads,ecam,edelbrock performer rpm 2 intake,75 mm tb,80mm lightning maf,30lb ford injecters,msd billet dizzy,zex n2o plugs,zex 175 wetshot
3400 stall converter,fmvb aod with transbrake and electronic od cancel,mark8 driveshaft,3.73 rear
13.86 n/a
12.13 on 100 shot
vristang
Re: 90 F150 5.0L EEC without a label with catch code
Post by vristang » Fri Jul 20, 2012 2:56 pm
Trial and error is the only way I know of...
Pull and save the .bin
Then try opening it with definitions that might work...
Hopefully there is a better way?
87 LX N/A 2.3 - CZAJL & EDIS
crakrz
Post by crakrz » Fri Jul 20, 2012 5:14 pm
I thought that the bins actually had that info in them. For example, if I open up my bin with hex editor, at address 27F**, or thereabouts, the strategy and bin numbers are actually listed. I don't know if this is just with our EECV 4 bank bins, or if its a common feature. Someone else, like sailorbob, may know more about it.
Aussie Tickford Falcon 2002 AU3 T3 TE50. Factory 5.6 Stroker Windsor, NVXF5 22KB.
joker772005
Post by joker772005 » Fri Jul 20, 2012 5:30 pm
i went threw all the bins on eecanalyzer and cudnt find any list for my truck
1989 cougar 5.0 efi
13.86 n/a
12.13 on 100 shot
joker772005
Post by joker772005 » Fri Jul 20, 2012 6:09 pm
i found a code inside of x9j
anybody crack that yet?
1989 cougar 5.0 efi
13.86 n/a
12.13 on 100 shot
Post by decipha » Fri Jul 20, 2012 8:12 pm
only eec5 contains strategy
prob speed density something close to a file i posted from a 93 f150
theres an automatic disassembly thread with some details but that wont help any
gt40ford
Post by gt40ford » Fri Jul 20, 2012 9:20 pm
Maybe , just maybe,
Since the binary is data, could you read the existing bin and run a simple hash/checksum on that and other known binaires and find the one that matches?
joker772005
Post by joker772005 » Fri Jul 20, 2012 11:21 pm
gt40ford wrote:Maybe , just maybe,
gonna take me a couple years b4 im smart enuff to understand what you said
yea this is for a non maf/vaf 1 o2 map sensor
1989 cougar 5.0 efi
13.86 n/a
12.13 on 100 shot
Post by decipha » Sat Jul 21, 2012 9:58 am
comparing checksums won't do you any good unless you just so happen to stumble across that exact binary which is very unlikely considering those ecu's aren't too well supported
now if you could compare the binary to other binarys and calculate the percentage of difference you'd then be on to something, if you could find a binary that had as much in common with that specific binary you'd be able to figure out what strategy it is
joker772005
Post by joker772005 » Sat May 17, 2014 2:25 pm
bringing this back up.....anybody crack it yet?
1989 cougar 5.0 efi
13.86 n/a
12.13 on 100 shot
LeadHead
Post by LeadHead » Sat May 17, 2014 10:32 pm
No, and I doubt anyone ever will. Very, very little interest in the Gen 1 EEC-IV Speed Density F-150 stuff. The only one that really has any support is the 351 E4OD lightning computer.
Post by jsa » Sun May 18, 2014 3:08 am
When I use ForDiag on my eec-iv, it reports strategy and catchcode from the eec-iv.
XantheFIN
Post by XantheFIN » Mon May 19, 2014 1:41 pm
ForDiag uses Checksum for that.
I would use those Calibration Pointers on 2020 or 0020=56K Addresses and look which Strategy uses same pointers. Example:
08 01 00 BF CA C0 A6 C3 60 CB A8 CF C6 D4 2A D7 A4 D7
European Zetec - GSAZ1 - ENVY
*ForDiag
*Innovate LC-2 WB
Post by jsa » Tue May 20, 2014 1:03 am
XantheFIN wrote:ForDiag uses Checksum for that.
When I have the GGR chip plugged in ForDiag reports CARD catchcode, rather than COSY of the eec-iv alone.
The GGR chip will have a different checksum to CARD, so does ForDiag really have the checksum and catchcode of 3rd party chips ?
XantheFIN
Post by XantheFIN » Tue May 20, 2014 4:07 am
Well i did not think that. But i thought that because everytime when i update my Tune it Checksum becomes different. And some times i get that my car become 4,6l and so on. But usually i get nothing else than Checksum over there to be displayed.
:confused:
*ForDiag
*Innovate LC-2 WB
Tomin
Post by Tomin » Wed May 21, 2014 2:55 am
Hi,
Fordiag uses, on EEC 4, a calibration ID. It is not checksum.
It is word transimtted from EEC in data stream.
Plus, fordiag has internal table with all calibration id / catch code / partnum,
so it can search rest of informations from calid then.
(I am creator of Fordiag, so it is confirmed information :-)
Tomas
Post by sailorbob » Wed May 21, 2014 1:14 pm
The calibration ID (aka CALID) was superseded by the checksum (aka ROM_TO) in the late '80's. The checksum forms a unique reference and there is another parameter (the FIXSUM) that is used to ensure the ROM_TO value is unique.
Once you change a calibration and recalculate the checksum this method of ecu identification no longer works.
Tomin
Post by Tomin » Wed May 21, 2014 2:53 pm
Superseded ? It works for me on all EEC IV models, so up to cca '1999 (Escort 1.6 Zetec, for example).
Post by sailorbob » Wed May 21, 2014 3:02 pm
The ecu is giving you the ROM_TO value when issuing the ROM Calibration ID in a DCL message.
BTW, nice work with your Fordiag s/w 8)
Tomin
Post by Tomin » Thu May 22, 2014 6:36 am
Oh, so. Thanks for a clarification.
Users browsing this forum: Bing [Bot] and 164 guests
