MikeB
Re: CBAZA base tune
Post by MikeB » Fri Sep 07, 2012 3:04 pm
roger
95 Cobra- CBAZA/T4MO, TFS 185, Victor EFI, AFM N-91, QH/LC1, FMS 42lb inj, 90mm LMAF, MAC 1 3/4 longtubes, X, race bullets, 4:30's with a coilover/tubular front end, Baseline rear suspension, Draglite big/skinny's! 150 shot of gas coming...
Perfect is the enemy of very good!
Tireburner163
Re: CBAZA base tune
Post by Tireburner163 » Sun Sep 09, 2012 1:04 pm
decipha wrote:yeah theres a bunch more in the cry def, sailorbobs has a little more than popsracing and is 8x cheaper but its only supported by be2010, you'll be happy with popsracing def though its a significant improvement over the xls
FYI, I've been running the SailorBob CBAZA def file with BE2012 for months now. *shrug*
1995 Mustang GTS. Stock bottom end, stock cam, Twisted Wedge heads, RPM II intake, 70mm turbo.
QH, BE, EA
Re: CBAZA base tune
Post by decipha » Sun Sep 09, 2012 1:33 pm
hows that possible?
mpaton
Re: CBAZA base tune
Post by mpaton » Sun Sep 09, 2012 2:34 pm
I understand why there are BEB files and don't have a problem with that. However when I downloaded your tune out of interest, I was surprised to find you'd sent out a .BEB. I would have thought something you were contributing as a CBAZA starting point and for discussion would have been a .BIN
So I have no comments on it as I can't read it.
Re: CBAZA base tune
Post by decipha » Sun Sep 09, 2012 2:52 pm
you can pm sailorbob if you have BE2010 he can send you a readonly
i think on the eecanalyzer site theres a read only as well
Tireburner163
Re: CBAZA base tune
Post by Tireburner163 » Sun Sep 09, 2012 4:57 pm
decipha wrote:hows that possible?
I don't know, it really wasn't even that big of a deal. I sent him an email and and the conversation went something like this (very paraphrased)
Me: I have BE2012 and I want to use your stuff
SailorBob: I've never tested this in BE2012, but see if you can open this read only in 2012
Me: Nope, that sucks
SailorBob: Oh....you should try this *random thing that I don't remember he told me to try*
Me: Sweet it works......here's money.
And I've been tuning with it in 2012 for months now *shrug*
QH, BE, EA
mpaton
Re: CBAZA base tune
Post by mpaton » Mon Sep 10, 2012 2:37 pm
decipha wrote:you can pm sailorbob if you have BE2010 he can send you a readonly
I'm sure he could, but I don't have any other use for it. Are you telling me that your only option is to save your bin encrpyted?
Re: CBAZA base tune
Post by decipha » Tue Sep 11, 2012 8:20 am
correct, otherwise it would be a bin, i'd prefer it a bin so others could use it too but thats not possible
fatstat
Re: CBAZA base tune
Post by fatstat » Tue Sep 11, 2012 10:06 pm
hey zerochance, different subject, what size kb pulley? <2"? with stock crank pulley? and where'd you get it? it's six rib?
lot of questions :)
95 GT manual, track only, not street driven
CBAZA-Tweecer-BE-EA
late 70's 302 block stroked 331 w TEA-ported twisted wedge 165 heads, comp cams XE284HR-10, kb 1.5 blower on GT40 lower @ 7-3/4lbs boost, C&L MAF black tube, summit 77mm tb, 60lb injectors, bbk long tube headers, no AC, no emissions (EGR, air pump, or cats), 3.73 8.8, torsen diff
fatstat
Re: CBAZA base tune
Post by fatstat » Tue Sep 11, 2012 10:12 pm
decipha, i'm really looking forward to working with this, and very much appreciate you posting it.
would you maybe have a 60# injector template? i'm using frpp specs now, but EA says my slopes should be 37/80, way off (this is with my tune, not with your tune)
my current tune pretty good, but recurring problem with hyper-rich on tip-in. maybe yours will cure it.
CBAZA-Tweecer-BE-EA
MikeB
Re: CBAZA base tune
Post by MikeB » Wed Sep 12, 2012 9:06 am
fatstat wrote:decipha, i'm really looking forward to working with this, and very much appreciate you posting it.
Did you shift your WB in EA, then run the injector calculation?
For me, I've found it helps, and shows me that I'm much closer than I thought with the Ford specs.
fatstat
Re: CBAZA base tune
Post by fatstat » Wed Sep 12, 2012 10:24 pm
did the EA calc, but no "shift your WB" --you mean the WB calibration tab in EA? i'll give it a look
hey, decipha, when i tried the tune, i set injector parms & the MAF. on start, crank is good, startup is good, then pw goes to 0 and stays there. what might cause that?
CBAZA-Tweecer-BE-EA
MikeB
Re: CBAZA base tune
Post by MikeB » Thu Sep 13, 2012 8:55 am
fatstat wrote:did the EA calc, but no "shift your WB" --you mean the WB calibration tab in EA? i'll give it a look
No. Datalog tab. After you open the new datalog, go into "Filters". Shift WB is one of the filters. I think the default is 5. You'll have to look at your logs to make an educated guess and take into account your WB location. Mine is further downstream in the exhaust, so I used 8.
fatstat
Re: CBAZA base tune
Post by fatstat » Thu Sep 13, 2012 8:31 pm
great, thanks, Mike. long tubes, so probably need something similar to yours.
CBAZA-Tweecer-BE-EA
MikeB
Re: CBAZA base tune
Post by MikeB » Thu Sep 13, 2012 10:38 pm
fatstat wrote:great, thanks, Mike. long tubes, so probably need something similar to yours.
No sweat. Make the adjustment and rerun the injector calc. See if it looks any better.
kbernal1016
Re: CBAZA base tune
Post by kbernal1016 » Tue Sep 18, 2012 5:44 pm
decipha:
I loaded up your base tune to see how my car responded, and after coping all the injector and maf data from a j4j1 tune, the car feels like its getting too much fuel. After it dies from backing out of the garage, it will not re-start, but just crank and barely catch.
Do you have a template for 24 pound injectors, for cbaza? 24lb ev1.
corral.net, svtperformance.com: kbernal1016
norcalsvtoa.com: meangreen95
95 Mustang 5.0, CBAZA, W4H0 w/ slightly modified J4J1 tune, B303, Gt40P's, Cobra intake, Full exhaust, All common bolt-ons 3550, IRS, Lots of suspension goodies, Moates QH, BE/EA, LC-1
Re: CBAZA base tune
Post by decipha » Wed Sep 19, 2012 12:22 am
the j4j1 injector info is what you want
sounds like u need to dial in idle air
can you email me your tune?
decipha at efidynotuning dot com
kbernal1016
Re: CBAZA base tune
Post by kbernal1016 » Sun Sep 23, 2012 2:17 pm
Email sent! Thank you!
Users browsing this forum: Bing [Bot] and 163 guests
