FinnCobra
Ford IDS ?
Post by FinnCobra » Thu Oct 11, 2012 1:45 pm
Does anyone use it, is there any custom programming abilities with it? Asking because found cheap china-clone shop. Any info about do clones work?
Ford Mustang Cobra -94. Focus ST 2013
Coretuning/Moates/HPTuners/Innovate/Tunernerd Knock Monitor/
Re: Ford IDS ?
Post by cgrey8 » Thu Oct 11, 2012 2:50 pm
What is IDS?
FinnCobra
Re: Ford IDS ?
Post by FinnCobra » Thu Oct 11, 2012 4:09 pm
http://www.motorcraftservice.com/vdirs/ ... s/ids/mcs/
http://www.motorcraftservice.com/vdirs/ ... evin=rules
http://www.dhgate.com/wholesale/ford+ids.html
I have used it in previous job, but now I dont have access to it. Thought that I'd buy one if got it cheap :oops:
TwinSCs
Re: Ford IDS ?
Post by TwinSCs » Thu Oct 11, 2012 8:25 pm
Personally I'd stay far away from the chinese clones. It's my understanding that there were good clones and bad clones. The good ones are supposed to be impossible to find nowdays. IIRC the IDS software just went through some major changes renderring clones just about useless as far as updating them.
If you are mainly concerned with flashing look at the Mongosse or the MCS1. Both will work with both BE and Fords web flash software.
If you want something more diagnostics oriented take a look at Focom, Autoenginuity, or Scanxl.
81 Mustang, 91 5.0 shortblock, GT-40 heads & intake, TFS1 cam, 24# bluetops, Explorer TB and FEAD, 73mm C&L Maf, BBK shorties, T-5 with 3.73s. Running GUFB on A9P with QH.
FinnCobra
Re: Ford IDS ?
Post by FinnCobra » Fri Oct 12, 2012 1:27 am
I have Equus 3140 obd1/2 tester for diagnostic. I was thinking of a device that can do more, and not just engine diagnostics. I must check these out, thanks for info.
POPSRACING
Re: Ford IDS ?
Post by POPSRACING » Tue Oct 16, 2012 4:29 am
sTAY AWAY FROM CLONES, i UTIILIZE ONE OCCASIONALT. tHE vcm 2 IS NOW OUT.
Land and Sea chassis dyno
1995 Cobra, 408, sold...
fordman2304
Re: Ford IDS ?
Post by fordman2304 » Sat Dec 22, 2012 1:33 am
have to purchase a license and is updated about every other day ids update 82.02b just came out for the fusion/escape fire recall. it is very expensive but worth every penny if one can afford it.
The wireless feature is very nice as stated above ...VCMII not recommened to reprogram modules via wireless but i havent ran into any problems with it picking up where it leaves off if something happens with connectivity,
88' ford ranger std cab
turbocharged 5.0L ,hyd cam "non-roller",iron heads,gt-40 upper/lower intake, 39lb inj,billet fuel rails,aeromotive f.p.r, Lightning fuel hat mod w/t 3pumps, c-4 trans, 2800stall, MOZ2 processor speed density...maf possible?
POPSRACING
Re: Ford IDS ?
Post by POPSRACING » Sat Dec 22, 2012 2:58 am
the last vcm was 980 plus 600 something for the subscription. Not bad for a shop, a bit pricy for DIY folks.
Users browsing this forum: No registered users and 47 guests
