wydopnthrtl
New.. introduction
Post by wydopnthrtl » Mon Dec 03, 2012 2:39 pm
Hello all,
I've been reading and reading here and decided to join because of the knowledge, friendliness, & I sure could use advise on tuning. And maybe I could help others in other ways. (OEM automotive engineer for 20yrs. 1/2 of which was @ Ford. I know the 4.6/5.4 inside out)
My car: I have a mostly stock, fair weather & 99% street driven 89GT w/T5. It has 126k on the clock & I am slowly building it with the goal of running 12.5s in pure street trim (93oct w/DA avg of 2000ft).
The car was stock when I bought it excpet for a 70mm TB and fresh paint. I've done the usual first steps w/a 5.0L which have woke it up quite a bit. In prep for tuning it I've replaced most of the sensors and installed an innovative MTX-L WB w/pinout harness.
Last winter I went 1st class on the rear end w/all new parts & 4.10s.
This winter I'm going with a T5Z, centerforce, & tuning.
Hopefully next winter I can do the engine.
ST Goal: Get the tranny done, tune it myself, and run a high 13 this summer in pure street trim. (245-45-17 all seasons)
LT Goal: Would be nice to go to the track after work, put on some ET streets or DR and run high 11s.
So I've pretty much decided on QH & BE but am not too sure what else I need to buy or how to hook up the WB for data logging. Any advise which other items I might buy and what is best for data logging with the MTX-L?
btw, I've successfully tuned 3 OBD2 fords w/SCT pro racer. I'm no expert.. but I have dipped my toe in the water. ;-)
He who is enslaved to the compass is free to sail the seas
Stock 89GT (Engine & T5 are factory original)
Engine mods: E-fan, Underdrives, AC delete, smog del, H-pipe, FM 40s, 70mm TB,Open air filter,Cap,rotor,coil,14deg timing
Rearend mods: 4.10s, 31spine, Detroit TT, C-clip elims, Steeda adjustable uppers, MM lower control arms
*Most sensors* have been replaced and has a Innovative MTX-L in-car WB w/pinout
14.5@97 granny shifting at 5400 (syncros are long gone)
wydopnthrtl
Re: New.. introduction
Post by wydopnthrtl » Tue Dec 04, 2012 12:14 am
Here is a pic of my stang..
incon_331_twinturbos
Post by incon_331_twinturbos » Fri Dec 07, 2012 11:45 pm
Very nice ride!!
Welcome to the forum!
Brad
1979 Ford Fairmont 4DR.
331, A9P, HPX 05+slot meter, SD 60# inj., T4MO, CBAZA, built AOD, Systemax U/L, TFS stage 2 heads, custom turbo grind 536/513 w 1.6rr , 224/218, 112* Int. CL, FMS 3.27, PonyDown Stg.3 turbo kit w/Turbonetics T76 (.96A/R), sumped tank with -8feed/-6 return, twin 225lph, aeromotive rails,
Moates QH, LC-1, BE/EA
StangD
Post by StangD » Sat Dec 08, 2012 5:55 pm
Welcome to the forum. What motor mods are allowed in the class?
94 GT-T5-347-CBAZA-TM40
QH-BE2012-Innovate LC-1
New Combo- 347-TW190FAC-Victor EFI-FTI Cam-42s-90MM LMAF-Accufab 85MM TB-Nitrous
Post by EDS50 » Mon Dec 10, 2012 12:39 pm
Good to see another red 89 gt around here.... Welcome!
Post by EDS50 » Mon Dec 10, 2012 1:13 pm
If you have the QH and BE already, your good. There is a write up in the faq on how to wire the innovate so you can log it in BE. The only other addition would be Clints Engine Analyzer where you can feed it your datalogs and it will analyze them and give you recommendations on what need to be changed in your tune. Check it out....
http://www.eecanalyzer.net/ea
You will also want to update your signature line to include which ecm you are using and strategy. You can use an a9l ecm and write a 93 cobra x3z tune to it for example.
wydopnthrtl
Post by wydopnthrtl » Sat Jan 12, 2013 10:27 am
Thanks guys, I've not been here much as I have a ton of work going on right now. But when I get a break I'll buy all the stuff and get to it.
Regards,
Rich
Post by decipha » Sun Jan 13, 2013 12:22 am
welcome to the forum, check out the links in my sig will give u most of the info u need to tune it
Users browsing this forum: No registered users and 8 guests
