Re: Inline parameters(arguments)
I see that there is a shift. I don't know why there's a shift.
I'll stick to my 'clue' approach, so it's not all free....
Those opcodes fall into logical operations, if I can put it that way (bit like a set of algebra or maths statements)
1. You know what 45a9 does.
2. then 45ab and 45ae (you should know what this does now)
3. then 45b1 to 45ba do something sneaky
4. then 45bf and 45c2 (as step 2)
5. then 45c5 is the last step
Ignore any more just for now.
So to step 2, you should be able to state what it does from previous discussions here.
Step 3 - see if you can work out WHAT and WHY, and what the result is.
This step is where mpaton and I probably disagree how to do this, but I can't see how else are we to make sense of this stuff. I'm open to any suggestions.
Try to think of those operations in a more 'maths' way to get the answer perhaps stick in a value and see what happens to it....
here is a piece of code which calls the subroutine at 45a9, in case it helps, and I've helped with data already.
Note that my pseudo code shows the shift as a divide - in this case it's actually NOT a divide as such - Typical - Murphy pops up....
3fd7: ef,cf,05 call 45a9 Sub1();
3fda: 83,60,8d,00 orw R0,[R60+8d] # probably data ?
3fde: c7,e4,fa,38 stb R38,[Re4+fa] [Re4-6] = R38;
3fe2: 01,30 clrw R30 R30 = 0;
In order for me to understand #3, I need to make sure my understanding of the opcodes are correct. Which was the point of an earlier post. I'll repost...
To get clarity on exactly what the instructions do, I've tried to find them explained in the eectch98.pdf but all that's there is a brief description of the instruction. Then I looked up the 8096 equivalent and looked up in its tech manual what it said about the instruction and it just had some verbiage about D<-A or something like that that wasn't helpful to me. If there is a better document that better details out the instructions, I should be looking there instead. Point me there, and I'll take another swag at it.
Is this correct or is my understanding of the instruction just wrong? If it is wrong, in what way?cgrey8 wrote:...The content of R33 is being put in R34 (45b1). And since R34 is being treated as a word and the instruction is "zero-extended," it's clearing R35 to zero....
So before I start caring about what the actual values of the registers are, I think it more important that I get confirmation that my understanding of the instructions is correct. IF that's wrong, then it doesn't really matter what I think the content of the registers is. I will be wrong.cgrey8 wrote:...Now 45ba is where I'm getting confused. It appears the upper nibble of the value that was in R33 was actually a pointer to a register (specifically a register in the R0-R15 range). So the value of that register is added to 0x00F0 and stored in R32. But didn't this just overwrite whatever value was stored in R32 at 45ab? So yeah...I'm confused. Did I misinterpret something or is this exactly what's happening up to this point?
ironmanisanemic
https://drive.google.com/folder/d/0B3c0 ... h1ZDA/edit
Check this out. To my knowledge it's the only tech data on the processor that was from ford that leaked to the public.
As far as understanding opcodes, ive been using my Google fu and just searching for those specifc ones, but nothing processor specific. From my understanding opcodes are fairly generic across most processors, there naming convention might just be a little different.
Hope this helps
Hope this helps
1989 Ford Bronco:
1995 Ford Mustang GT
I've stalled at 45BA.
3F3B EF???? call L45A9
3F3E 8E00 word $008E
3F40 B600 word $00B6
or maybe we have
3F3E 8E byte $8E
3F3F 00 byte $00
3F40 B6 byte $B6
3F41 00 byte $00
PC contains 45A9
SP contains 3F3E
45A9 CC36 L45A9 popw REG_36
CC is POP DIRECT
0x3F3E is taken from the top of the stack and stored at R36
PC contains 45AB
SP contains ----
REG_36 contains 3E Address LSB
REG_37 contains 3F Address MSB
45AB B23732 ldb REG_32,[REG_36]+
B2 is LDB INDIRECT
The address at R37/R36 is 0x3F3E. 0x3F3E has the byte 8E
8E is copied to R32
The address at R37/R36 increments by 1 to 0x3F3F
PC contains 45AE
SP contains ----
REG_32 contains 8E Data Byte
REG_36 contains 3F Address LSB
45AE B23733 ldb REG_33,[REG_36]+
B2 is LDB INDIRECT
The address at R37/R36 is 0x3F3F. 0x3F3F has the byte 00
00 is copied to R33
The address at R37/R36 increments by 1 to 0x3F40
PC contains 45B1
SP contains ----
REG_33 contains 00 Data Byte
REG_36 contains 40 Address LSB
45B1 AC3334 ldzbw REG_34,REG_33
AC is LDZBW DIRECT
R33 contains 00 and is Zero Extended to 0000
The 00 at R33 is stored at R34
The 00 extension is stored at R35
PC contains 45B4
SP contains ----
REG_34 contains 00 Word LSB
REG_35 contains 00 Word MSB
45B4 710F33 an2b REG_33,#$0F
71 is AN2B IMMEDIATE
0F is added to the content of R33
0F+00=0F The result 0F is stored at R33
PC contains 45B7
SP contains ----
REG_33 contains 0F Data Byte
45B7 080434 shrw REG_34,#$04
08 is SHRW DIRECT
R34/R35 WORD is 0x0000
Which is BINARY 00000000 00000000
Shifted 4 Right 0000 00000000
Pad Left with 0 00000000 00000000
0x0000 is stored to R34/R35
PC contains 45BA
SP contains ----
REG_34 contains 00 Data Word LSB
REG_35 contains 00 Data Word MSB
45BA 6735F00032 ad2w REG_32,$00F0[REG_34]
67 is AD2W SHORT INDEXED
R35/R34 contains 0x0000
Signed Byte 0xF0 evaluates to Decimal -16Cheers
it doesn't look like your stuck, i didn't go over the stuff above but as far as 45ba you've basically got it
34/35 is accessed as a word, it is ADDED to reg32W along with 0x00F0
it can be expressed as Reg32 += [Reg34 + 00F0]
if may be easier if you think of reg34 as being a pointer and 00f0 as being an offset, if reg34 truly equals 0 then its simply taking the value at register F0
(which usually is base address pointer)
Thanks, didn't pick up it is long indexed, but sorted now.decipha wrote:it doesn't look like your stuck
Thanks to Sailorbob, TVRfan & Decipha, having got a handle on L45BA I have continued on with the example.
I have fixed an error I made at line 45B4.
A number of lines seem to end up with unknown results, so I have not completed all the detail for follow on lines.
Please have a look and critique away.
Hopefully void of stupid typo's, it all looks good at this point in time.
PC contains 45A9
SP contains 3F3E
CC is POP DIRECT
PC contains 45AB
SP contains ----
B2 is LDB, 37 is odd so INDIRECT AUTO
8E is copied to R32
PC contains 45AE
SP contains ----
REG_32 contains 8E Data LSB
00 is copied to R33
PC contains 45B1
SP contains ----
REG_33 contains 00 Data MSB
AC is LDZBW DIRECT AUTO
PC contains 45B4
SP contains ----
REG_34 contains 00 Address LSB
REG_35 contains 00 Address MSB
71 is AN2B IMMEDIATE, so 0F is a Byte of data
R33 holds 00
0F is BINARY 0000 1111
00 is BINARY 0000 0000
ANDED BINARY 0000 0000
0F AND 00=00 The result 00 is stored at R33
PC contains 45B7
SP contains ----
08 is SHRW DIRECT
PC contains 45BA
SP contains ----
67 is AD2W, 35 is odd, so LONG INDEXED
F000 is a data WORD 0x00F0
0x0000+0x00F0=0x00F0 the target address
The WORD content of the target address 0x00F0 is not known
R32 contains 0x008E
0x008E+Unkown content of target address 0x00F0 is stored at R32
PC contains 45BF
SP contains ----
REG_32 contains ?? Data LSB
REG_33 contains ?? Data MSB
45BF B23734 ldb REG_34,[REG_36]+
The address at R37/R36 is 0x3F40. 0x3F40 has the byte B6
B6 is copied to R34
The address at R37/R36 increments by 1 to 0x3F41
PC contains 45C2
SP contains ----
REG_34 contains B6 Address LSB
REG_36 contains 41 Address LSB
45C2 B23735 ldb REG_35,[REG_36]+
The address at R37/R36 is 0x3F41. 0x3F41 has the byte 00
00 is copied to R35
The address at R37/R36 increments by 1 to 0x3F42
PC contains 45C5
SP contains ----
REG_36 contains 42 Address LSB
45C5 C836 pushw REG_36
C8 is PUSHW DIRECT
R36 contains 0x3F42
0x3F42 is placed on the stack
PC contains 45C7
SP contains 3F42
45C7 B23434 ldb REG_34,[REG_34]
B2 is LDB, 34 is even so INDIRECT
The address at R35/R4 is 0x00B6.
The content of target address 0x00B6 is unknown
The unknown content is stored at R34
PC contains 45CA
SP contains 3F42
REG_34 contains ?? Address LSB
45CA 9B320234 L45CA cmpb REG_34,$02[REG_32]
9B is CMPB, 32 is even so SHORT INDEXED
The content of R32 is unknown
The content of R34 is unknown
Signed 0x02 equates to +2
Target address is unknown address+2
PC contains 45CE
SP contains 3F42
45CE 3D9D04 jb REG_9D,BIT_05,L45D5
3D is JB, D indicates 5th bit of contents of R9D
Signed 0x04 equates to +4
If the 5th bit of BYTE in R9D is 0 then PC is 45D1
If the 5th bit of BYTE in R9D is 1 then PC is 45D5
45D1 DB0A jc L45DD
DB is JC, Carry flag is a bit in the Program Status Word
Signed 0x0A equates to +10
If the Carry bit of PSW is 0 then PC is 45D3
If the Carry bit of PSW is 1 then PC is 45DD
45D3 2002 sjmp L45D7
20 is SJMP
0x20 is 0010 0000 Binary
0x02 is 0000 0010 Binary
Jump offset is signed 000 0000 0010 which equates to +2
PC is 45D7
45D5 D606 L45D5 jge L45DD
D6 is JGE, Negative flag is a bit in the Program Status Word
Signed 0x06 equates to +6
If the Negative bit of PSW is 0 then PC is 45DD
If the Negative bit of PSW is 1 then PC is 45D7
45D7 65020032 L45D7 ad2w REG_32,#$0002
65 is AD2W IMMEDIATE
0x2 is added to the unknown content of R32
45DB 27ED sjmp L45CA
27 is SJMP
0x27 is 0010 0111 Binary
0xED is 1110 1101 Binary
Jump offset is signed 111 1110 1101 which equates to -19
PC is 45CA
45DD 71DF9D L45DD an2b REG_9D,#$DF
71 is AN2B IMMEDIATE, so DF is a Byte of data
Content of R9D is unknown
DF is BINARY 11011111
45E0 B23336 ldb REG_36,[REG_32]+
B2 is LDB, 33 is odd so INDIRECT AUTO
45E3 B23338 ldb REG_38,[REG_32]+
45E6 7A3236 sb2b REG_36,[REG_32]
7A is SB2B, 32 is even so INDIRECT
Content of R36= Content of R36 - Content of address from R32
45E9 7A3334 sb2b REG_34,[REG_32]+
7A is SB2B, 33 is odd so INDIRECT AUTO
Content of R36 = Content of R36 - Content of address from R32
Content of R32 is incremented by 1
45EC 7A3238 sb2b REG_38,[REG_32]
Content of R38= Content of R38 - Content of address from R32
