ender11
what is this chip?
Post by ender11 » Thu Jan 04, 2018 2:32 am
here: http://www.allfordmustangs.com/forums/5 ... ost4003562
looks like it's a replacement for a stock rom, but who makes it?
skunk
Re: what is this chip?
Post by skunk » Thu Jan 04, 2018 7:26 am
Not sure what chip your referring to. The only mention of a chip in that thread is the SCT.
Post by cgrey8 » Thu Jan 04, 2018 8:19 am
Agreed.
The service port edge connector is where you install tuning devices. Tuning devices can be simple chips OR they can be more complicated devices like the TwEECer or Moates Quarterhorse which interact with a PC to allow you to update tunes without removal of the chip and to perform realtime datalogging.
ender11
Post by ender11 » Thu Jan 04, 2018 1:41 pm
feel free to push on the thumbnail in the post I reffered. or attached photo. here rom chip of a9p computer is replaced with something different. have you seen this before?
Post by cgrey8 » Thu Jan 04, 2018 4:46 pm
I'm assuming you are referring to that component on a daughter board with a hand-written white label. That's the "old school" way of replacing a ROM. This is the Chevy EEC way of having to upgrade a ROM. Because Ford put that edge-connector on the EEC, that's not necessary. You can get the same EXACT result by putting a chip on the edge connector WHILE keeping the stock chip right where it is on the main board. It's possible this setup is something Cardone did if they couldn't acquire standard DIP chips.
ironmanisanemic
Post by ironmanisanemic » Fri Jan 05, 2018 12:57 am
It's not an official product moates sells, but he developed that device for certain racing classes that banned external chips or chips that plug in. So by replacing the internal rom chip with your tune it would be possible to pass tech inspection. It's supposed to be able to be programmed while it's installed with a special cable and a burn2.
1989 Ford Bronco:
1995 Ford Mustang GT
Post by cgrey8 » Fri Jan 05, 2018 6:14 am
ironmanisanemic wrote: ↑Fri Jan 05, 2018 12:57 am It's not an official product moates sells, but he developed that device for certain racing classes that banned external chips or chips that plug in. So by replacing the internal rom chip with your tune it would be possible to pass tech inspection. It's supposed to be able to be programmed while it's installed with a special cable and a burn2.
I never knew about that rule OR that Moates had a work-around for that rule. What was the reason for that rule in the first place given it can be skirted via direct chip replacement?
ironmanisanemic
Post by ironmanisanemic » Fri Jan 05, 2018 9:04 am
I believe it was a loophole that is being exploited. Something about having to be stock in appearance or something like that. It's been years since I was told about them. Can't remember the exact rule that was being worked around.
1989 Ford Bronco:
ender11
Post by ender11 » Fri Jan 05, 2018 6:16 pm
it must be a flash chip soldered on the other side of this green board?
Users browsing this forum: No registered users and 49 guests
