nickcamarata
using a 4.6 ecu and harness on a 351w?
my main goal is to have a 351w that is obd ii compliant. would it be possible to use the ecu and harness from a 4.6 out of a mustang or something like that? or is it easier to use the ecu and harness from a 5.0 explorer? the car the 351 is going into is going to be manual. im starting out with the bare f4te block so what sensors would i need as well. another option i was thinking about is finding a 96 or 97 f250-f350 with the 5.8 and using everything off of it.
Re: using a 4.6 ecu and harness on a 351w?
From your previous thread, the sticking point isn't running a 4.6L or 5.0L EEC on the 351w. It's that you didn't want to go the EDIS (coil pack) route and thus are trying to maintain a TFI distributor on the 351w while also running an OBD-II compliant EEC. That's the killer combination that I'm not sure there's a Ford solution for.
If there is, I'm interested in what that year/make vehicle is too.
1996 F150 5.8L was OBD2 and had a distributor/TFI ignition system.
nickcamarata
If I have to run coil packs I can do it.
What strategy and EEC did they use? And is it EEC-IV or EEC-V?
No idea on strategy. It has a 104 pin connector so has to be EEC-V
That's getting close!
Now the next big question is, is it MAF or SD-based?
Looking at Google-images of "1996 F150 engines", it looks like it just might be MAF which means we have a winner!
Definitely MAF
nickcamarata
yea those trucks should be maf. so thats probably my best option? now just gotta find a 96 parts truck
The other question is what does OBD2 compliant mean in this case. Where I live the testing has changed over the years. Originally they just checked for a PASS code in the EEC. Now they want to see a PASS code plus make sure all the monitors have completed. A 1996 F150 may not have all the monitors this BMW had and if they are looking for that it would be an issue.
nickcamarata
I live in NY pretty sure they just check to make sure there are no codes
That's a good question. Now one of the things I always "assumed" is that when they checked the monitors, they were simply checking that the monitors that were active, were a PASS and "trusted" that the not-applicable monitors actually didn't apply.Paulie wrote: ↑Tue Jul 03, 2018 12:42 pm The other question is what does OBD2 compliant mean in this case. Where I live the testing has changed over the years. Originally they just checked for a PASS code in the EEC. Now they want to see a PASS code plus make sure all the monitors have completed. A 1996 F150 may not have all the monitors this BMW had and if they are looking for that it would be an issue.
Otherwise, the State's Emissions computers would have to query a database which had a list of all make/year/engine variant combos that ever existed and what I/M monitors were applicable for each.
The only real "deep dive" check I thought they did was verify that the VIN, if available, matched what the Emissions tester entered for the vehicle being tested. But since VIN presence didn't exist until a few years AFTER 1996, it was acceptable for them to not have the VIN, which I doubt a 1996 F150 EEC would.
Is any of that a bad assumption based on knowledge about how State emissions computers really work?
nickcamarata
Is it possible to reprogram the ECU and put in the VIN of the beamer?
Users browsing this forum: No registered users and 52 guests
