Serial control of the Burn2 and Jaybird
Post by motorhead1991 » Thu Jun 13, 2019 1:12 pm
I've read the documentation a handful of times, so I get the gist of it, but there are a couple things I'm stuck on:
This command specifically has me stumped:
'J'+'R'+n+MMSB+MSB+LSB+CS
J and R are ASCII values, obviously, but no notes are given for 'n', MSB or LSB. MMSB has a note, saying that it should be between 0 and 3, which is what 'n' is in the previous command.
Any clues, hints or tips?
Re: Serial control of the Burn2 and Jaybird
Post by jsa » Thu Jun 13, 2019 2:35 pm
EDIT, REREAD PROTOCOL INFO and chaged my opinion.
Most most significant byte, most significant byte, least significant byte and checksum all bundled together in that order.
Post by motorhead1991 » Thu Jun 13, 2019 2:58 pm
jsa wrote: ↑Thu Jun 13, 2019 2:35 pm n is the number of bytes of data to follow in the range of 1 to 3.
Most most significant byte, most significant byte, least significant byte and checksum all bundled together in that order. Leaveing out M and MM for n=2 and 1.
And you lost me again :grin:
Post by jsa » Thu Jun 13, 2019 3:14 pm
Edit; new interpretation of protocol doc below.
Post by motorhead1991 » Thu Jun 13, 2019 3:21 pm
jsa wrote: ↑Thu Jun 13, 2019 3:14 pm Each byte is a hexadecimal number.
N=03
xx xx xx cs
N=02
xx xx cs
N=01
xx cs
I think I see... So I had the command partially correct:
4a 52 31 33
J  R  1  3
MSB and LSB are where I get stuck.
Post by jsa » Thu Jun 13, 2019 3:43 pm
Hmm plenty of scope for misunderstanding that protocol doc.
MSB and LSB must be a word address of a chosen bank to read from.
Either n or MMSB must be the bank number and inversly MMSB or n must be how many bytes to read.
Edited above posts, let us know which way works.
Post by jsa » Thu Jun 13, 2019 4:13 pm
I reckon set n as 00, mmsb as 00, msb as 00 and lsb as 00 followed by cs. That should get 256 bytes from the begining of one of the eecv banks.
Post by sailorbob » Fri Jun 14, 2019 1:29 am
My understanding of it is:
n = number of bytes to read (starting from the address defined by MMSB, MSB, LSB)
MMSB = bank ( 0, 1, 2 or 3)
MSB = high byte of address
LSB = low byte if address
It will probably baulk if you try to read more bytes than there are between the start address and the end of the bank.
