A9L Fan control
I just ventured into the topic of controlling my Mark VIII Fan with the EEC using the Tweecer. I went on and hooked everything up as if it would work mainly cause it if doesn't I can still trigger the fan on with another source. Well I was checking mine out last night and Pin 41 does not provide enough ground to trigger a relay. My question is this.. has anyone tried to trigger a transister? The transister does not require as much current to switch as much as the relay does to trip the contacts.
Anyone ever tried this? Mike, do you see any thoughts on this? Do you know the ouput impedence of pin 41?
Brian
Brian
306 (stock block),TFS Track Heat Heads, E303 Cam, TFS track heat intake, 70 mm TB, 75mm Pro-M,42 lb injectors,Aeromotive AFPR, 255 lph intank, Crane Hi-6/LX-92. Turbonetics 60-1 hi-fi
A9L using Binary Editor
93Cobra#2771
Brian. sounds kinda risky to me to start using transistors, etc. Course, I'm no electrical guru by any stretch.
I'm in the middle of my mk8 instal, along with a dccontrol.com fan controller. Don't know if you know anything about them, but they are awesome. It will power your fan using pulse width modulation, and will maintain the temp with only the power needed. It also eliminates the high start up spikes for the mk8, as well as the high amp draw at all times.
www.dccontrol.com
model #fk-35
www.dccontrol.com
model #fk-35
Richard White
X3Z, RT, GT40y's, ported intakes, Steeda #18, AFM PP, 80mm Pro-M, MSD, MAC E/L, Dr Gas X, 3.73, etc.
I do Reproduction Mustang Window Stickers!
"Tweecer Defs" http://autos.groups.yahoo.com/group/twe ... mentation/
Yea that looks like a good unit to use, however, the $$$ does not. I am gonna try and check into the transister setup sometime this week.
I know that the meter would indicate a ground but when I loaded it, it killed the output. I think it maybe really really low current output.
thunderstang
I could not find one of the PNP transistors that I was looking for to complete my circuit, so I opted for a low current relay.. it works.. one question though... I had the settings set at HS fan on at 192°, HS fan off at 188° fan hysteresis at like 4. I don;t hvae my laptop here at work so I don't the specfics other than thoses... but the fan would come on at 192° fine, but it would not turn off until like 180°. Could this just be the time delay before it would shut off due to the speed of the eec, or is there another setting I need to adjust... I don't plan on using those numbers but just used those as a testing point for the car.
- 86GT
- BE/EA Developer
I am in the process of installing a electric fan from a 94 Taurus. I read what I could about pin 41 and so on. The fan I got is a dual speed single fan. I also got the control module with it. It came with all of the relays and wiring for the control module. Everything was 40$ at Pick N Pull. I had to reverse engineer it, but I figured everything out and it works great with the control module.
My question is, does anyone know what the high and low speed outputs pins are on the EEC. I know of pin 41, but there should be another for the second fan speed. If anyone has a 94 + book that shows the pins it would be appreciated if you could look it up and tell me.
Oh yah, is pin 41 the high or low?
94-95 5.0L Mustang -
Pin 55 is the LOW
Pin 32 is the HIGH
They go to that CCRM relay module, which controls the A/C compressor, turns on the fan, and fuel pump. SO the computer might not kick on the fans for the A/C, the relay module might do that on it's own.
Pin 55 is the LOW
Pin 32 is the HIGH
Ryan McCormick
Ford Fuel Injection.com
- 86GT
- BE/EA Developer
WOW, no pin 41. Yes I also have the CCRM that operates the fans. The CCRM has four relays and an AC coil transistrer relay logic.
Relay 1 (K1) is the PCM power, which is a 3 amp relay
Relay 2 (K2) is the Fuel Pump Power, which is a 3 amp relay
Relay 3 (K3) is the High Speed Fan, which is a 40 amp BOSH relay
Relay 4 (K4) is the Low Speed Fan, which is a 40 amp BOSH relay
K3 is a fail safe on relay, This means it take a gorund signal from the EEC to turn the low speed fan off, while K4 is the opposite, it takes a gound signal from the EEC to turn it on. This allow the low fan to operate if the ECT temp sensor or ciricut goes bad.
Thanks for the info.
Has anyone used the A9L series with a two speed fan?
Clint,86GT wrote:WOW, no pin 41. Yes I also have the CCRM that operates the fans. The CCRM has four relays and an AC coil transistrer relay logic.
I think you have the K3 and K4 backwards..?/? what are your intentions? are you wanting the low speed to come on with the key and high speed to come on at the higher temps?
- 86GT
- BE/EA Developer
K3 and K4 are correct. 3 = high and 4 = low.
I would like to use the CCRM the way it was intended by FORD. When I have the module wired up, and I leave pins 14 & 17 diconnected the low speed fan is on and the high speed fan is off. If I ground pin 14 (Low Speed Enable) the low speed turns off. If I gound pin 17 (High Speed Enable) then the High speed turns on. I believe Ford did this to prevent overheating if the temp sensing ciricut went bad.
If the ciricut went bad then yes the low speed fan would come on with the key (Fail Safe). If the ciricut was Ok then the EEC would apply a ground if the minimum temp is not met and release the ground when the low speed fan is commanded to turn on.
My intent is to find the two pins on the A9L series EEC that will accomplish the above requirements for the CCRM.
twinturbostang
I seem to remember someone talking about the low speed pin on the EEC. Don't remember what pin it was though. I also don't remember if it was actually hooked up or not. Try searching the forum for those messages.
Oh, high speed is definitely pin 41 though. I have that hooked up with my Mark VIII fan and A3M combo.
www.twinturbostang.com
93Cobra#2771
For some reason or another, I want to say there isn't actually a low speed setting on the A9L family. Don't quote me on that, however.
Richard White
93Cobra#2771
Let me rephrase - the settings are there, but the hardware in the EEC is not???
Richard White
thunderstang
- 86GT
- BE/EA Developer
Just for an update:
I was able to verify pin 41 being the high speed enable. I tried the remaining open pins thinking that one of them had to be the low speed, but was unsucessful. I took the cover off of the EEC to find that most of the spare pins are not connected to anything. Below is a list of pins that are spare:
2 ( Not connected to any componets internally)
5 ( Not connected to any componets internally)
8( Not connected to any componets internally)
11( Not connected to any componets internally)
18( Not connected to any componets internally)
23( Not connected to any componets internally)
24 ( Connected to some componets)
28( Not connected to any componets internally)
34( Connected to some componets)
35( Connected to some componets)
39 ( Connected to pin 40 internally- Ground)
41 ( High Speed Fan Enable)
44( Not connected to any componets internally)
51( Connected to some componets)
53( Not connected to any componets internally)
55( Connected to some componets)
I am going to continue to research the topic.
twinturbostang
As has been said here, I believe the low speed fan is one of those pins not connected to anything. It's as if the pin was designated for low speed fan, but it had not been implemented yet. If this is the case, you might have to build your own circuit that enables low speed upon criteria that you select (A/C on, temp in certain range, etc.).
24 has been used for the cam sensor (CID) on EDIS swaps86GT wrote:Just for an update:
Some 3.8L cars used pin 31 for the fans High speed 13 for the low
13 is an injector on the A9, but 31 is the CANP.
is it possible to remove the CANP and use that pin / driver for the fan?
- 86GT
- BE/EA Developer
I agree that I maybe barking up the wrong tree, but If ford enabled a high speed, where is the low?
As twinturbostang stated, " It may not be there hardware wise". This maybe possible. I maybe wasting my time, but I have to say that I am stubborn, and have to prove it before I give up. If it does not appear to be there then I will most likley build my own ciricut.
I hope it does not offends anyone.
I also found that pins 2,5,18,23,24 are inputs and pins 34,35,41,51 are outputs.
twinturbostang
Well, definitely let us know what you find! :)
- 86GT
- BE/EA Developer
I found that one of the required IC is missing. It is an 71001FB chip that can not be bought. It has been off the market for nearly four years.
I 8061 CPU is outputing the signal to the chip location but since the chip is missing, not ouptput is felt on the J1 connector. I was temped get the cip from a wreked car from the bone yard but. They are vary senitive to temperature. A good heat sink may do it while trying to un solder them, but the did a butcher job on getting them in there.
wa_4x4builder
Hmmm, it's interesting how these topics come up at the right time for me. I just grabbed all the components at the pick-n-pull this weekend for 5 bucks to do this conversion (minus the fan). I was wondering the exact same thing- which TWO pins run the fan on the A9L. I know of pin 41, but what pin do you think is the other speed circuit? (the one you say is missing the IC?)86GT wrote:I found that one of the required IC is missing. It is an 71001FB chip that can not be bought. It has been off the market for nearly four years.
Chris
'93 EDIS 5.0L with A9L installed into a '77 Bronco.
wa_4x4builder
Did you mean 41 by chance instead of 51? (not trying to be a smarta$$, just clarifying).86GT wrote:The chip that controls the fan has four output pins. The output pins goto J1 35, 51 and 55. I did not trace the last one. I am guessing but I think it is going to be pin 55
Chris
Hello,
I have read this thread with interest. I too wanted to configure the EEC to use a dual speed fan. 86GT, doing my research I also supposed that 51 was the pin that would control low speed of the fan. I also wanted to use a CCRM from a 94-95 Mustang and wire it to a 93 Mustang ECM. I followed pin 51 back on the board and found it stopped at the missing 16 DIP which I believe is either IC5 or IC6. I have found on the internet that the chip is still available at some locations. Do you think that it would be doable?
Is this the location that you suspect also?
http://www.schofieldcomputer.com/myCoup ... EECTop.jpg
Ron
Ron
Users browsing this forum: Google [Bot] and 25 guests
