WA2FAST
Low RPM bucking... can it be cured?...
Post by WA2FAST » Thu Oct 27, 2005 9:51 am
I just finished tuning a friends car on his TwEECer, he has a 90LX, 347, 10.5:1 compression, all of the goodies, stout motor. He likes driving his car in his neighborhood at very low RPM's for noise reasons and I can't talk him out of it. I have drivability nailed on it perfectly, but when he gets down around 1500rpm, it starts to buck really bad. I attribute 95% of this to the cam... it's bassicaly a .600 lift B303 cam (I can't remember the exact specs right off of the top of my head). Is there ANYTHING I can do to try to remedy this at all? I don't think there is, but I could be wrong. Please let me know if you have any ideas, thanx!
-Don-
87' GT, A9L, TwEECer RT, P1SC@12psi Non-Intercooled, AFM PP, 3" Pro-M#42, 70mm TB, GT-40 Intake, GT-40X Heads, B303, 1.6, BBK 1-5/8" Long Tubes, 306 Built Bottom End, Probe Block Girdle, TR3550, 3.55, PLX WB, Jan 07 Modified Mustangs Feature Car
Paul
Post by Paul » Thu Oct 27, 2005 10:28 am
Mine 347 has perfect drivability and will lug @ 1000RPM in 5th all day long. My cam isn't that big (E cam with 1.72RR) but it used to buck like crazy until got the load and the maf correct. I nailed the MAF with my LC-1's and then nailed LOAD with some 3rd gear WOT runs.
SHaFT7
Post by SHaFT7 » Thu Oct 27, 2005 10:30 am
i'd like to see your tune paul...specifically your sealevel load table :D
91GT, TwEECER R/T, A9L mods
back to NA H/C/I for now, turbo combo coming this fall!
02 ZX-6 - stock
WA2FAST
Post by WA2FAST » Thu Oct 27, 2005 10:45 am
That's just it though... the KAMRF's on his car are damn near perfect... that's why I say it's probibly the cam, maybe something with timing, I don't know... Mine with the B303 cam is perfect down low as well, but I can get another 300-400 out of it... that could just be the difference in cams though. I don't ever drive my car down that low so I don't care... but he does.
-Don-
Paul
Post by Paul » Thu Oct 27, 2005 10:48 am
WA2FAST wrote:That's just it though... the KAMRF's on his car are damn near perfect... that's why I say it's probibly the cam, maybe something with timing, I don't know... Mine with the B303 cam is perfect down low as well, but I can get another 300-400 out of it... that could just be the difference in cams though. I don't ever drive my car down that low so I don't care... but he does.
My KAMRF's where perfect as well but commanded was in the 16 - 17 range. It took my wideband to get it right. Now the KAMRF's = commanded = wideband and all is right in the world 8)
Paul
Post by Paul » Thu Oct 27, 2005 10:49 am
SHaFT7 wrote:i'd like to see your tune paul...specifically your sealevel load table :D
I'll post the LOAD table after work.
Jack Hidley
Post by Jack Hidley » Thu Oct 27, 2005 6:17 pm
A friend of mine, Nate, solved this problem a while ago. Here is the link to the problem and solution he posted.
viewtopic.php?t=5434&highlight=
It has always shocked me that Ford wasn't able/willing to solve this problem on the several hundred thousand EEC-IV/V Mustangs that they sold over the years.
Jack Hidley
Maximum Motorsports Tech Support
WA2FAST
Post by WA2FAST » Thu Oct 27, 2005 8:28 pm
Looks good, thank you very much for the info, I'll give that a shot the next time I work on the car.
-Don-
Users browsing this forum: Bing [Bot] and 40 guests
