stangfreek94
Big power, blower guys. Let me see your spark tables
Post by stangfreek94 » Thu Feb 02, 2006 2:04 am
Just want to get a better idea, if I'm in the right ballpark. The car feels super strong. It's just sometimes at the top of 3rd and 4th, I get a little hesitation. Not all the time. I think it could prolly use some more timing. Or, a maybe a lil' leaner. Without the meth injection, I see @ 22* at 5200 on up. Haven't really tried to add much more with the meth yet. Only been up to 26* with the meth. I think I've got it set pretty aggressive, just want to compare. My AFR is right around 11.7:1 all the way through. Some spikes to 12.0:1, and down to 11.3:1. I've only been running with the 255 intank. I had some problems trying to keep the base fuel pressure down with the 255 intank & 255 inline, and the stock rails and lines. So, I pulled the fuse on it. The fuel pressure goes up to @ 55 psi. This may also be the hesitation, or I guess it could be a lil' belt slip, or spark. Just curious to see what you guys have for your setup.
I see @ 13-14#s at 5900-6100 rpm, with the stock SQ pulleys on my combo. Logged maf flow of 2,04x, I can't remeber what the voltage was off the top of my head. Something like 4.2 volts.
I can't wait to see what it does this summer. Just got everything running real good. Still trying to get the kams closer to perfect with the slopes, before I mess with the maf curve anymore. So, I can tweec the ISC settings, and the throttle body airflow. I also still have to install my new fuel system, and shocks- struts.
Can you paste a screen shot of your spark tables? Thanks, Joe
94 GT, New PTK turbo, TW heads, TFS stage 1 cam, 75mm TB, 60#inj., full aeromotive fuel system, Snow stage 2 meth injection, forged 306, PLX wideband, PMAS pro tube Blowthru
Vortech Times 10.80 @ 126.44 mph, with a 1.57 60ft. 3600#s
JuiceSC
Post by JuiceSC » Thu Feb 02, 2006 7:28 am
26* :shock: You got ballz. :D Even 22* is agressive with that much boost. 26* for me resulted in a popped HG. (my own fault, forgot to take out timing) I'm running 18* and it seems to work well with only 8 psi. I *may* try a little more at the Glen this year......maybe.....
Dale McPeters
Post by Dale McPeters » Thu Feb 02, 2006 8:55 am
JuiceSC wrote:26* :shock: You got ballz. :D .
I agree with this statement....... :wink:
BE & EEC Analyzer
Paul's EEC-Editor
stangfreek94
Post by stangfreek94 » Thu Feb 02, 2006 11:56 am
26* was with the meth. injection. Only tied it twice, and is was recently, with the cold air. So, if I were gonna have any problems. It should be this time of year. You never know what you can do, til' you try it. It runs great at WOT, kinda scary fast. :lol: I think the TW heads tend to like more timing than others. Post up some ballsy spark tables.
89blownssv
Post by 89blownssv » Thu Feb 02, 2006 2:04 pm
I'm running 24* at wot with 22 lbs boost non intercooled.
using 110 octane fuel.
89 Coupe 302, Paxton Novi2000, TFS heads, 83 lb injector, A9P, TwEECer R/T
90 GT 302, Paxton Novi2000, TFS heads, 42lb injectors, A9L, TwEECer R/T
99 35th anniversary GT 4.6l Procharger P1SC
42 lb injectors, Lighting MAF,Tweecer R/T
JuiceSC
Post by JuiceSC » Thu Feb 02, 2006 4:58 pm
stangfreek94 wrote:26* was with the meth. injection. Only tied it twice, and is was recently, with the cold air. So, if I were gonna have any problems. It should be this time of year. You never know what you can do, til' you try it. It runs great at WOT, kinda scary fast. :lol: I think the TW heads tend to like more timing than others. Post up some ballsy spark tables.
Ok, I can see 26* with meth.....errrr...methanol. hehehe Your right though, my heads do have the "fast burn" chambers and specifically say not to run more than 28* N/A.
JuiceSC
Post by JuiceSC » Thu Feb 02, 2006 4:59 pm
89blownssv wrote:I'm running 24* at wot with 22 lbs boost non intercooled.
Thats not fair. :lol:
boss96
Post by boss96 » Fri Feb 03, 2006 9:12 am
Since you have one fuel pump disconnected I would be very careful. In the higher gears you have more load, or a better way to put it, the load is higher for a longer time due to the gearing.
What is your fuel pressure at the top of 3rd and 4th when you fell the hesitation? You may need to put a better fuel system in, like bigger rails, etc.
As far as timing goes, I can't speak directly for 5.0 motors but I would be conservative using pump gas, you already damaged some pistons recently, why take a chance? Use the 50/50 water/meth mix for more timing, then I feel confident you can add 7-8 degrees more timing from your pump gas tune safely.
BTW, did you replace all the pistons or just the damaged ones? I would do a leakdown test on all cylinders to know for sure the conditon of the motor.
Bob
96 GT, Vortech Si trim,Procharger 3 core intercooler, forged bottom end, MAC longtubes, ported PI heads , Edelbrock intake, Crower cams-.580lift/234dur@.050, 80lb injectors, CDAN4/GGL4 processor.
Dale McPeters
Post by Dale McPeters » Fri Feb 03, 2006 9:38 am
Bob, Are you think about Warren when he broke the pistons
in his engine from running to much timing?
BE & EEC Analyzer
Paul's EEC-Editor
89blownssv
Post by 89blownssv » Fri Feb 03, 2006 10:37 am
Thats not fair.
What part is not fair?
the timing?
the boost?
the fuel?
The fact it is all going through a stock shortblock with stock pistons? :o
JuiceSC
Post by JuiceSC » Fri Feb 03, 2006 1:19 pm
89blownssv wrote:
Thats not fair.
the timing?
the boost?
the fuel?
I was just teasing, but I was refering to fuel. I kinda took his question with pump gas in mind. :D
boss96
Post by boss96 » Fri Feb 03, 2006 1:56 pm
Dale McPeters wrote:Bob, Are you think about Warren when he broke the pistons
You're right, Dale, mixed up the cars :oops:
Bob
89blownssv
Post by 89blownssv » Fri Feb 03, 2006 4:56 pm
I
ok, I agree with your timing specs on pump gas. :)
My combo don't run too good on pump gas.
It detonates and pushes out the headgaskets. :cry:
But it really likes the 110. :D
JuiceSC
Post by JuiceSC » Fri Feb 03, 2006 5:34 pm
89blownssv wrote:My combo don't run too good on pump gas.
I'm thinking 22#s of boost may have something to do with that.... :D
2Shaker
Post by 2Shaker » Fri Feb 03, 2006 7:44 pm
Yeah, it was me who burned 3 pistons with 30* of timing and 12 lbs boost. Not a pretty sight. And hot lapping it didn't help as the ACT's were really up there.
I read this thread right away because the motor is back in the car and its time to put more reasonable timing tables in TwEECer.
Dale, BTW, I resent the pictures, were you not able to open?
stangfreek94
Post by stangfreek94 » Fri Feb 03, 2006 7:54 pm
Guess I'll just stick with what I have been running. It seems to like it. I think the hesitation is prolly a fuel volume problem. I'll have to get to work on getting my new fuel system in as soon as possible. This is with pump gas, if that wasn't clear before.
stangfreek94
I'll post up my spark tables sometime this weekend, if I get the chance.
Dale McPeters
Post by Dale McPeters » Sun Feb 05, 2006 7:25 pm
2Shaker wrote: Dale, BTW, I resent the pictures, were you not able to open?
Warren,
No sir. Something is stripping the pictures out before they even get to
my internet service provider. I will drop you an email with a different email address to try. You should have it after while.
BE & EEC Analyzer
Paul's EEC-Editor
Shaker666
Post by Shaker666 » Mon Feb 06, 2006 5:27 pm
Guys, don't forget that you simply don't need that much timing to maximize power output in a blown application. Spark advance in an N/A setup is there to give the combustion enough time to burn properly to make good power; in a blown car, the combustion and flamefront propogation occurs much faster due to boost. Therefore, the more boost you run, the less timing you need to properly synchronize the combustion events.
Dale McPeters
Post by Dale McPeters » Tue Feb 07, 2006 8:43 am
Shaker666 wrote:Guys, don't forget that you simply don't need that much timing to maximize power output in a blown application. Spark advance in an N/A setup is there to give the combustion enough time to burn properly to make good power; in a blown car, the combustion and flamefront propogation occurs much faster due to boost. Therefore, the more boost you run, the less timing you need to properly synchronize the combustion events.
:wink:
BE & EEC Analyzer
Paul's EEC-Editor
SHaFT7
Post by SHaFT7 » Fri Feb 10, 2006 10:25 pm
with my setup, i ended up adding 8 deg everywhere on the spark tables (except WOT, which is signficantly reduced). this was the _only_ way to get rid of the horrendus bucking/popping/stumbling with any load between idle and wot.
do i need to be worried about burning pistons or anything? i'm setup for ~9.4:1 with a powerdyne and 9psi. my afr is under 12.0 at all times during WOT
91GT, TwEECER R/T, A9L mods
back to NA H/C/I for now, turbo combo coming this fall!
02 ZX-6 - stock
Shaker666
Post by Shaker666 » Sat Feb 11, 2006 4:03 am
SHaFT7 wrote:with my setup, i ended up adding 8 deg everywhere on the spark tables (except WOT, which is signficantly reduced). this was the _only_ way to get rid of the horrendus bucking/popping/stumbling with any load between idle and wot.
I don't think that adding 8* everywhere is a good idea at all. I would keep the tables stock and try to tune the MAF to resolve your bucking/stumbling problems. I ended up using the stock tables, but reducing the timing by about 20% for the highest load row, 15% for the 2nd highest, and around 8% for the 3rd highest row. I'm 19* at 5000 RPM, WOT. Runs quite well at ~14 psi.
SHaFT7
Post by SHaFT7 » Thu Feb 16, 2006 11:18 pm
interesting... picked up power in the midrange....
the afr always looks good....
don't aluminum heads need more timing? especially since i'm using 91 octane over stock iron heads with 87?
also, this is only part throttle...wide open still has the timing way reduced for the blower
btw, my roommate with TW heads (57cc at that) stock cam and a HP stage 1 turbo kit had to do roughly the same thing to get the bucking gone and be able to drive around normally
02 ZX-6 - stock
Shaker666
Post by Shaker666 » Sat Feb 18, 2006 4:04 am
I've always attributed bucking to an untuned MAF curve, as has largely been the case in my experience. The timing never had anything to do with it, at least on my car.
stangfreek94
Post by stangfreek94 » Sat Feb 18, 2006 9:14 am
All these opinions and advice. I've still not seen 1 spark table yet. Which is what I asked for.
Cougar5.0
Post by Cougar5.0 » Sat Feb 18, 2006 10:03 am
stangfreek94 wrote:All these opinions and advice. I've still not seen 1 spark table yet. Which is what I asked for.
Reasons I didn't provide any info:
1. I don't consider my setup to be high power SC
2. You asked for a table then seemed to talk about the WOT spark function
3. My table is stock except for scaling of the Y-axis (load)
FN904A - Sealevel Spark:
___500 700 900 1100 1300 1500 2000 2500 3000 4000
1.00 8 8 9 10 11 13 21 21 21 21
0.80 8 8 9 10 11 14 21 21 21 21
0.66 15 16 16 16 18 20 26 27 27 27
0.52 20 21 25 32 34 34 33 32 28 28
0.38 25 26 30 37 38 36 36 38 28 28
0.24 28 28 33 37 37 38 38 38 28 28
0.10 28 28 28 32 34 35 35 34 28 28
0.05 28 28 28 31 33 34 34 34 34 34
FN131 - WOT Spark Advance Function:
0 1000 1800 2150 2600 3700 5000 6000 6400
8__8__18.5_21.5_22.5__23___26__26___0
I also have meth injection but I rarely get that WOT spark due to FN135 settings:
FN135 - WOT Spark Advance vs. ACT
-256 120 150 180 210 240 254
__0__0___0__-1_-3__-6__-10_
428w now
stangfreek94
Post by stangfreek94 » Sat Feb 18, 2006 1:53 pm
Mine's pretty similar. (CBAZA)I don't have access to the WOT spark advance function though. I do have spark advance rate vs RPM, but it's some kind of multiplier. I really just wanted to get some ideas, of what everyone else was running. Thanks for posting it up.
db1994
Post by db1994 » Sun Feb 19, 2006 1:00 pm
Most all the turbo/intercooler guys I know (including myself) run 21 degrees total under full boost/load at anywhere from 6-15psi and seem to have pretty good success with it using pump gas.
What you can get away with is typically inversely proportianate to your ACT - which you didnt post.
-Jason
| 1994 Mustang Cobra #4594 |
| Tweecer RT | J4J1 | Zeitronix WB |
| HP Turbosystems Stage 1 Turbo |
| 567hp 647tq @15PSI|
Shaker666
Post by Shaker666 » Fri Feb 24, 2006 3:43 am
db1994 wrote:Most all the turbo/intercooler guys I know (including myself) run 21 degrees total under full boost/load at anywhere from 6-15psi and seem to have pretty good success with it using pump gas.
-Jason
This is true, but you need to also be aware of your existing compression ratio - what it really is, not what you think it is.
SHaFT7
Post by SHaFT7 » Sun Feb 26, 2006 7:46 pm
ok, my WOT timing tables go from 24 down to like 18....so i have THAT covered.
using the 03 Cobra maf curve out of EA, I pretty much don't have to touch it at all using my LMAF. everything is within the KAMRF's range to correct. with the bucking/stumbling still there, that points to timing. adding the degrees helped 150%. (i even tried a race plug, which helped some, then the computer learned its way around it). with the timing, it is good all over the place. (there are a couple spots i need to fine tune, but 98% of the table is great)
with the wideband showing correct, and no red flags showing, i think this is what my car just wants.
91 octane, box stock TW heads, b-31 cam, and a powerdyne @ 10psi
02 ZX-6 - stock
Users browsing this forum: Bing [Bot] and 49 guests
