Hey I new and this my frist post, hope I doing this right.
I just got my TwEECer RT, I still in the what this tag do leaning, I was trying to load up 4 tunes with with defent setting: I was trying load up the timing tables, and some the scalars adder, mostly to see if what I put in the table or the scalars machs with my timing light.
But try cheak the 4 tunes by reading them back, I found my setting was not on the tune I thought it would be, so I start over loaded a stock tune all all 4 slots, all read back good, then made an ez to read change to each slot, found that what wight too slot 1 goes to 1 and 3, and like wise what write to slot 2 is on slot 4. so 1 and 3 is always the same and same for 2 and 4. also it slot 5 reads same as 1 and 3, it read and write to this slot too if the means some thing, figger that slot 5 would read as slot 1 or whould not read. Ok it maybe helpfull to know I doing this on my desktop with the TwEECer not pluged in the EEC. Also I runing an older EEC code VL2 (DA1 famly) its out of 86 Mark VII with an HO, it replaced my bad DA1, I using the DA1 bin from the TwEECer web page, seem to work well mostly about the same, maybe hire better. Well I hope that there none thing wrong with my TwEECer RT as I just got it.
Well help or thoughts would be grate
FastRat, Dave.
85 mustang LX
87 5.0L, ported heads, sorty header, 2 1/2" H flow master, SROD, 3.08-8.8
VL2 86 HO (DA1 like)
